cosworth wire rung block
Old Aug 10, 2012 | 08:27 PM
cozi500's Avatar
cozi500
Default cosworth wire rung block
Hi all, ive recently purchased a second hand cosworth engine with the head gasket blown, once i stripped it down i notice on each cylinder of the block there was a ring that was raised above the block face, im unsure if this has been modified or had new liners, you cant move the rings there solid,any help please
Old Aug 16, 2012 | 08:23 PM
daz1968's Avatar
daz1968
Probably just wore rings to help the head gasket seal, used to be common on cosworth engines and involves machining grooves in the block and putting wire in them. Not used as much now, but nothing wrong with the method,
Old Aug 17, 2012 | 11:23 AM
teenwolf's Avatar
teenwolf
I heard once its been wire rung, and the head lifts, the block is pretty much trashed? This was some years ago though, I could well be way off the mark...
original
Apr 28, 2026 05:20 PM
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
