Please Help - FRST Running Weird!
Old Apr 22, 2004 | 08:16 PM
Default Please Help - FRST Running Weird!
Can anyone help?
My frst wont run at all with the map sensor disconnected.
If you disconnect the vacume pipe into the map sensor and leave it with air leak the car will drive fine and idle fine apart from it will misfire on boost.
If you connect the vacume pipe into the map sensor it wont idle and judders when you first pull away but feels great when on boost.
HELP!!! Is this a fueling issue? If so what do I do?
Cheers.
Old Apr 23, 2004 | 08:28 AM
Anyone?
Old Apr 24, 2004 | 01:51 PM
oriont's Avatar
oriont
have you checked idle valve and coolant temp sensor mate?? also CO
thanks
oriont
Old Apr 25, 2004 | 08:32 AM
Checked and replaced every sensor mate apart from the cps!
I doubt its that but I might give that a try too cause there are a few stories on the net of faulty ones giving similar probls, people believe they either work and your car runs or they dont and your car doesnt run but I not sure...
Somethings well odd!
Cheers.
Old Apr 25, 2004 | 10:42 AM
oriont's Avatar
oriont
im sure if cps is knackered it wont start but try unplugging it and see what happens
thanks
oriont
Old Apr 25, 2004 | 11:44 AM
yeah if you unplug the CPS it won't start as there will be no spark, i would give the ISCV a clean and maybe try a new TPS, and then go and get the base idle checked out.
Old Apr 25, 2004 | 11:49 AM
make sure the bit of loom & plug that go on the c.p.s. are ok & not heat damaged.
if they are, you can buy a replacement part from ford, there not dear.
Good luck.
Old Apr 28, 2004 | 09:28 PM
Checked and replaced cps, speed sensor and iscv now.
Still no joy, it wont idle and stubles a little bit on moving slowly. Seems ok apart from that.
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
