Over-revving problem KA
Old Jul 21, 2012 | 08:15 AM
neilio82's Avatar
neilio82
Default Over-revving problem KA
Hi,my 2000 Ka has a problem with over-revving, which has got worse the past few days. basically when accelerating the engine can over-rev and take a while to "catch-up" with itself. the problem is much worse when going up hill or accelrating hard. been doing a fair bit of research on the tinterweb, and a lot of posts are reccomending disconnecting the battery for 30 mins, cleaning the ICV and TPS, the first two i'm going to have a crack at today, but i'm worried it might be the clutch slipping, as most of these posts ive read say the problem happens (over revving) when taking the foot of the clutch, whereas mine is definately during acceleration and a couple of times when coming to a stop.
Be intresting to know if anyone else has had the same problem and been able to do anything about it.
Thanks in advance.
Old Jul 21, 2012 | 08:57 AM
oldford's Avatar
oldford
If you mean the engine is revving hard during acceleration, but you're not building up speed, then yes the clutch is slipping.
Old Jul 21, 2012 | 09:08 AM
neilio82's Avatar
neilio82
it does build speed up still, just takes a massive amount of revs for it to get anywhere, but like i say, it's pretty much fine at low speeds (no over revving at all in first) and on the flat, just when i want to build up a bit of speed or go up hill is when it gets worse...??
Old Jul 21, 2012 | 09:18 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Sounds like the clutch is slipping to me!
Old Jul 21, 2012 | 06:52 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Yep, sounds like clutch to me too!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
