Light and electric mirror problem
Old Jul 16, 2012 | 06:27 PM
James Edgar's Avatar
James Edgar
Default Light and electric mirror problem
Right this is a long winded problem so I hope it makes sense
My interior light fuse has blow since stripping my sierra for its repaint but now I'm on the build up I've found that my electric mirrors do not work
When I put a fuse in the interior fuse place my n/s indicator come on not flash but solid light up and when I move my mirror switch the drivers side mirror clicks but does not move no matter what side it's put to even set in the middle it clicks
Any help on problem?
Old Jul 16, 2012 | 06:34 PM
martysmartie's Avatar
martysmartie
I would say that due to the paint, earth points are no longer a good connection
Electricity will always take the path of the least resistance, so if you have a bad earth connection it will take another route, i.e via the indicators it may be in your case.
Again, the mirror may not be able to draw the power it needs, for the same reason (Assuming there isn't a problem with the mirror)
Martin
Old Jul 17, 2012 | 08:04 PM
James Edgar
The problem
The solution
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Vincereese
Sep 5, 2015 10:46 PM
Bailes1992
Sep 3, 2015 02:17 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
dlwarrior
Aug 5, 2015 10:19 AM
