Cosworth Engine cut @ 4250 (sometimes)
Old Mar 3, 2005 | 07:36 PM
palmer3914's Avatar
palmer3914
Default Cosworth Engine cut @ 4250 (sometimes)
I have just had my 2wd cosworth re-built - everything.......
its stage 3 as in .. greens, T34 etc ..... it did 3 engine / boost cuts first off, lower down then higher up...... so the map sensor was re-wired and got rid of 2 of them.... so it was then tested with another map sensor which was proven to be Good... it caughed once at 4250 then over the next 4 runs didn't..... So went and bought another map sensor..... now if i toe it 9/10 throttle fine!!!!! BUT when i peddle to the carpet does the cut again at 4250 ish .... almost a boost cut.. then recovers v-quickly and carrys on as normal............ any ideas????????????
HELP
like to add everything is new, leads, dist, coil etc everything
Old Mar 4, 2005 | 10:11 AM
icecossie's Avatar
icecossie
check if there is any air getting out at the intercooler (might just be a tiny leak)
That was the problem i had...
Old Mar 4, 2005 | 02:00 PM
palmer3914's Avatar
palmer3914
everything seems to be ok .............. but still happening .... doesn't happen in 1st and 2nd gear just in the higher gears ..... and is ok if i wind it in smoothly and keep it off the carpet!!! but if i nail it it happens sometimes twice in a row one after another then recovers and pulls !!! ???
HELP!!!!!!!!!!!
Old Mar 4, 2005 | 09:00 PM
martinmace's Avatar
martinmace
amal valve could be faulty?? just a thought
Old Mar 6, 2005 | 10:23 AM
palmer3914's Avatar
palmer3914
i shall be trying that today ....... i assume i can prove this by simply unplugging the amal valve ..... more lag yes i know but should this then prove it?????
Old Mar 6, 2005 | 01:14 PM
davidreader5's Avatar
davidreader5
HI,
WITH AMAL VALVE UNPLUGGED, LESS LAG, YOU NEED TO CHECK WITH A BOOST GAUGE WHAT BOOST YOU ARE RUNNNING FOR THE CHIP SETUP.TO SEE IF
OVER BOOSTING .
Dave R.
Old Mar 6, 2005 | 05:43 PM
Chuckboost's Avatar
Chuckboost
are you running non standard leads?
Old Mar 6, 2005 | 06:08 PM
A.Moore's Avatar
A.Moore
What chip you using.............is it a copy?? Plugs and gapping?
Old Mar 6, 2005 | 10:03 PM
palmer3914's Avatar
palmer3914
leads are magnicore ..... chip is an amber performance one i think ... and yes its a copy...... plugs are fine as are gaps i belive..
big_Rad
Sep 15, 2017 09:36 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
