Mk3 2.0 tddi Mondeo issues
Old Jul 4, 2012 | 09:32 PM
bigtel's Avatar
bigtel
Default Mk3 2.0 tddi Mondeo issues
In the torrential rain last Thursday my wife had to drive thru massive flood. The car the broke down but started again. But when ever I start it white smoke plumes out the back, when I dip the clutch it vibrates and when idling the judders quite badly. Someone says the Conrod might be bent but not sure! Help cheers
Old Jul 4, 2012 | 09:33 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
compression test it then
Old Jul 5, 2012 | 10:54 AM
bigtel's Avatar
bigtel
How do I do that?? Cheers
Old Jul 5, 2012 | 04:53 PM
saph4be's Avatar
saph4be
As said you need a compression test kit! More than likely bent a con rod though with those symptoms.
Old Jul 5, 2012 | 08:07 PM
bigtel's Avatar
bigtel
Someone mentioned the con rod is that a new engine if it is the con rod? Thanks
Old Jul 5, 2012 | 08:18 PM
Take the air box out and check its not flooded with water ,had the same thing a while back after we went through a ford that was depper than we thought ,loads of white smoke no boost and running on three ,stopped dried it all out new air filter all good done about 4k miles in it since ,no issues
155lee
Sep 6, 2016 11:10 AM
nico12
Dec 31, 2015 04:42 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Chopshop85
Sep 12, 2015 06:42 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
