3door sierra fuel sender help!?!!
Old Jul 1, 2012 | 03:46 PM
jimmy/taylor's Avatar
jimmy/taylor
Default 3door sierra fuel sender help!?!!
I've just spent the weekend re-installing my rebuilt YB engine into my 1.6 3door sierra shell. It's a group N rally spec shell running a 200block 4x4 engine. I noticed this afternoon that the fuel tank is rotten and has started to weep the tank has a Kevlar composite guard which was hiding this leak. It needed a drain hole so water didn't collect in it. Anyway, I removed the tank and noticed two of the four sender wires are broken(the fuel gauge had not worked properly since I got the car) One is live and the other one is seperate wire with a rubber plug going to a thread next to the sender plug,im guessing this is the earth,which isnt anymore!!! The other two looked like they were cut on purpose!
How many wires does the sender need to make it work properly?
Does the sender talk to the ecu?
It has an L8 ECu fitted.😖
Old Jul 1, 2012 | 09:09 PM
daz1968's Avatar
daz1968
Maybe the extra wires are for the low level warning light on the dash
Old Jul 3, 2012 | 12:32 PM
martysmartie's Avatar
martysmartie
Sender does not talk to ECU (well it does to the AWS ECU)
Basically this is the system that provides the low coolant, brake pad, fuel warning lamps etc, being yours is a different shell it may not have this, as only high spec models did.
As said Is suspect the extra wires are for the warning lamp perhaps?
Martin
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
robbo9006
11
Sep 1, 2015 02:10 PM
andyrs1600i
Aug 30, 2015 07:21 PM
