I need your help, MTX75 on Focus ST170
Old Jun 23, 2012 | 09:55 PM
wrc62's Avatar
wrc62
Default I need your help, MTX75 on Focus ST170
Hello!
Sorry for my bad english, i am from France!
I drive in rally with an ST170, but my gearbox Getrag6 is too long and Quaife gearkits are too expensive for me.
A friend give me a MTX75 gearbox from a Focus zetec 2.0 16v, more short than the Getrag. It's a Mtx75 with a command by cables.
What part i have to change, for fitting the MTX75 on my Focus ST170?
Driveshafts?
Gearcables?
Flywheel/Clutch?
Other parts?
Thank you very much for your help!
Old Jun 24, 2012 | 12:40 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Originally Posted by wrc62
Hello!
Driveshafts?
Gearcables?
Flywheel/Clutch?
Other parts?
you will need to change every think you have listed. you will need the mk1 focus shafts the gear cables are also different so you will need the ones out of the mk1 focus.. the st170 uses a duel mass flywheel and has a clutch that will nor work with the mtx box so you will need the mk1 focus flywheel clutch ect.
the hydro clutch line differs as well as the gearbox top mount and the back mount
Old Jun 24, 2012 | 04:49 PM
zippyobrien's Avatar
zippyobrien
Think you'll have to run focus Rs hubs aswell if you want to run decent breaks. As normal focus hubs have the slider built in.
Old Jun 24, 2012 | 05:18 PM
SiST's Avatar
SiST
i have a low mileage flywheel and clutch i bought for a mate who then went for a focus RS AP setup and some mtx75 focus mk1 gear cables - you can have them all for 40 posted if you want?
Old Jun 24, 2012 | 06:52 PM
RichieST's Avatar
RichieST
To France?
Old Jun 26, 2012 | 11:33 AM
Michal_ST's Avatar
Michal_ST
Hello wrc62!
I own ST170 and use it only for racing, trackdays etc, stock Getrag is too long and slow for me too so I'll do the same conversion soon... I already bought MTX75 with 4.06 final gear ratio and Quaife LSD.
As far as I know we need:
clutch/flywheel
gear selector and cables
driveshafts
maybe starter?
but what about vehicle speed sensor connected to the gearbox? It's different for sure and it will make some problems, did you think how to solve them? Do you use standalone management or stock ECU?
Old Oct 26, 2012 | 05:25 AM
fordman72's Avatar
fordman72
Hi, I am also doing this conversion, I have a ST170 I use for circut racing in Australia, I have a Quaife dog gear set I am going to fit to the MTX75, Please keep me informed with what progress you have made, I will pass on any information I can help with. I am looking for a good quality alloy flywheel and race clutch, if you know of any brands that fit please let me know.
Cheers Paul
Old May 21, 2013 | 09:23 PM
Michal_ST's Avatar
Michal_ST
Hello Paul,
It took some time but it's done, I can confirm that MTX-75 gearbox will work in ST170 All you have to change is:
clutch/flywheel
driveshafts
gearbox
I used lightened flywheel from stock Focus 2.0 Zetec:
but you can use an alloy one from CFM:
http://focus.c-f-m.com/fidanzabillet...tecexcsvt.aspx
there are some clutch or clutch/flywheel sets too.
The only issue after swap is speedometer readings are 3,6 times lower that a real speed so be carefull
Some onboards from my car after swap (training sessions):
(rear cam)
and have a look how we race in Poland:
How is your conversion?
Please share some more info about your car and your setup for circuit, what suspension, brakes, tyres, aerodynamics mods etc do you use? Please show how you race in Australia!
If you have any questions feel free to contact me.
Cheers,
Michal
Old Sep 23, 2013 | 10:28 AM
Freeked's Avatar
Freeked
Sorry to bring this up....but isn't there a way to have the speedo reading right? Like putting the speed sensor for the MTX75 gearbox?
Old Sep 27, 2013 | 09:30 PM
Churtz's Avatar
Churtz
The "Jaycar speedo corrector" will adjust the signal and read correct.
Old Oct 4, 2013 | 10:49 AM
fordman72's Avatar
fordman72
Originally Posted by Michal_ST
Hello Paul,
clutch/flywheel
driveshafts
gearbox
WST Real Race runda II Ułęż (21.04.2013) Ford Focus ST170 - YouTube
WST Real Race runda II Ułęż (21.04.2013) Ford Focus ST170 tylna kamera - YouTube (rear cam)
Focus ST170 vs Volvo S40 370 KM - YouTube
Nissan 370Z BRT - OPP WST Real Race - 12.05.2013 - YouTube
OPP WST Bogart Cup 21.04.2013 - YouTube
Cheers,
Michal
Hi Michal, Sorry for the delay in responce, conversion was no problem, I used the Clutch masters alloy flywheel and tripple plate clutch,Quaife dog gear set conversion. I have the Bilstien coilover kit in my car, very happy with it, handles quite well. I have fitted cross drilled rotors and use the standard calipers with ECB yellow stuff pads, I have a willwood pedal box. We have a control tyre in our class which is Yokahama AO50 225/45/17, excellent tyre but expensive here. I will post some incar when I work it out, but here is some pictures.
https://www.facebook.com/paul.redman.779
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
massivewangers
30
Oct 1, 2015 07:40 PM
cossirob
Sep 16, 2015 07:39 PM
pie-face
Sep 15, 2015 10:43 AM
