RSturbo running problems
Old Jun 11, 2012 | 08:28 PM
BlackRST MB's Avatar
BlackRST MB
Default RSturbo running problems
My rsturbo won't rev up. This was its first start in a long time!
Boost gauge shows -16psi when its ticking over and when i put the throttle down it goes to 0psi but the car stalls.
Has an idle of 1k and goes up to 2k on it's own. I need to double check the plugs on the inlet. Would this cause it??? Any advice welcome! cheers marco
Old Jun 11, 2012 | 08:54 PM
BlackRST MB
https://passionford.com/forum/ford-e...lp-please.html
Going off the picture in this thread I have swapped the black and the blue plug because they were wrong on my car. The vacuum gauge now shows 0, good or bad?
I cant find the brown plug? The grey one is currently where the brown one should be? But no sign of the brown plug or the place where the grey connector should go.
Coolant gauge shows 0 even though the car is warm.
Old Jun 11, 2012 | 09:07 PM
E980VTJ's Avatar
E980VTJ
when on tick over it should be negative,when revved with no load will go to 0,wait for someone to come along but deffo running ruff
Old Jun 11, 2012 | 09:28 PM
BlackRST MB
Just double checked the plugs on it. I dont seem to have a grey one I have a black one instead that has 3 pins into it?
The plugs are all correct though.
Old Jun 11, 2012 | 09:31 PM
BlackRST MB
Would a bad earth cause this because I think there is one missing and I have a random wire and connector hanging around. I hate other people projects!
Old Jun 11, 2012 | 09:40 PM
BlackRST MB
It did run a lot smoother than that after a couple of minutes but it would not rev up?
Old Jun 11, 2012 | 09:52 PM
steven8230_00's Avatar
steven8230_00
could it be the throtle position sencer on the throtle body
dont give in
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
