swapped Zetec to D2.3, now electrical problem
Old Jun 11, 2012 | 04:16 AM
SVTyler's Avatar
SVTyler
Default swapped Zetec to D2.3, now electrical problem
Hey guys. I just swapped a built D2.3 into my ST170 but now it is acting like the battery is not hooked up. I have continuity to the starter motor but nothing else. When I turn the key there is no lights or sounds or anything. I have double checked the battery connections and all grounds and most of the connectors.
I had my car and a donor car down to bare shell and swapped over everything. full wiring harness, ECU, PATS, fuel system, etc, etc
any suggestions?
thanks
Old Jun 11, 2012 | 04:14 PM
nevsrevs's Avatar
nevsrevs
checked relays, make sure you got voltage going through?
Old Jun 14, 2012 | 03:21 PM
SVTyler's Avatar
SVTyler
Thanks for the input. I found that the main junction box wasn't getting power so I fixed that and it started right up!
JoeyBoyden
Jan 4, 2024 02:36 PM
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
