Cosworth breather help!
Old May 30, 2012 | 04:37 PM
2ndGear's Avatar
2ndGear
Default Cosworth breather help!
I am running a 4x4 cosworth 380bhp with a bailey breather system fitted.
After a run and the car is parked up it is pissing oil out of the bottom pipe (the one that goes to fresh air!)
Is this normal or any mods i can do would a catch tank stop this or should i drain it back to the sump?
Old May 30, 2012 | 10:00 PM
Toe Knee's Avatar
Toe Knee
Shouldnt be pissing oil out of there mate, thats the over flow!!!
Have you checked the return pipe is clear and working ok?!
Old May 30, 2012 | 10:34 PM
2ndGear's Avatar
2ndGear
i will do that tomorrow then
Old May 31, 2012 | 07:29 PM
porterste's Avatar
porterste
Surely the bottom pipe returns to the sump. The top one would be the overflow
Old May 31, 2012 | 08:01 PM
MrC's Avatar
MrC
mine does this brown oil on the road, even more when its been driven hard
Old Jun 1, 2012 | 09:20 AM
Toe Knee's Avatar
Toe Knee
On a bailey kit the top two are breathers for where the kidney box is and the cam cover, the smaller bottom one is the return and the big bottom one goes to atmosphere
Old Jun 1, 2012 | 09:26 AM
COCHYN's Avatar
COCHYN
Ideally the 2 top ports on the Bailey tank should have 1 hose to where the kidney box was and 1 hose to the port underneath the turbo (which normally has a blanking plug fitted and you will need an adequate fitting to use as a breather). Then the smaller pipe under the Bailey tank should be a return to the sump (which you'll need to have boss welded onto the sump) and the larger one on the tank is to atmosphere. Then blank the breather on the cam cover.
You shouldn't have any problems if it's set up like that, if you do then there's a problem.
Old Jun 2, 2012 | 11:48 AM
Toe Knee's Avatar
Toe Knee
Ideally yea, but most people dont want to take their sump off to have a boss welded to it.
Hence a lot of people have it the way i said...........
Althou you can get an m14 union and replace the sump plug with it then have an angled adapter fitted so that it returns to there instead of welding a boss on the sump.
Old Jun 2, 2012 | 12:41 PM
COCHYN's Avatar
COCHYN
If you want to avoid issues, then the proper way is how I posted above, so people should be just a little assed if they want their engines to last. Then you can cancel the breather out as an issue
Old Jun 2, 2012 | 02:23 PM
BRAMMER's Avatar
BRAMMER
Bailey sell the kit to fit in to the cam cover, turbo side of block and to the kidney box and alot fit them with no issues - i had one on mine and it worked for the spec - never had a puddle of oil underneath so yes you do have an issue somewhere and i drove mine real hard without issues
Old Jun 11, 2012 | 03:33 AM
MrC's Avatar
MrC
so is the cam cover not the correct way as this is how mine is and i sometimes get oil out of the vent to atmosphere pipe??
Blockage??
also might be why i'm getting smoke when i accelerate after going slow.
Old Jun 11, 2012 | 09:47 AM
COCHYN's Avatar
COCHYN
Possibly, clean out the breather tank thoroughly till the water stops going yellow. Otherwise, might be your rings or stem seals maybe. Whole possible reasons. Having the breather at the cam cover isn't a bad thing, but the block needs to breath on both sides, so it would be ideal if you can open the port under the turbo up and have a pipe on the tank for that.
Old Jun 11, 2012 | 01:37 PM
MrC's Avatar
MrC
Will I be able to do that on my existing setup or do I need a different separator??
Engine was rebuilt 3000 miles ago and valve stem seals were fine when head was off recently a few needed doing and they were done before it was put back together,
How do you recommend cleaning system out?
Old Jun 11, 2012 | 01:41 PM
COCHYN's Avatar
COCHYN
Yeah mate, just get a blanking screw on the cam cover because most of the breathing needs to be done from down below in the block.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
kevin36
Sep 2, 2015 06:24 PM
