distributor advance curves
Old May 23, 2012 | 06:32 PM
durham fiesta's Avatar
durham fiesta
Default distributor advance curves
I have a dizzy on my mk1 xr2 that has a fixed advance curve . It was set as a fast road curve for use with twin 40s etc . Can any advance curve be timed to any engine ? Current spec is 1660 x flow , standard head , standard carb , 1300 pistons and a fast road cam Problem i am having is its pinking once the second choke is opened and can't seem to get the timing set right . Could it be a combination of fuelling and timing being wrong ?
Old May 24, 2012 | 01:12 AM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Im afraid i can't be of much help, but a mate of mine is well into mini's and he knows a guy who's the only person to bother seeing about dizzy curves. He does all the custom ones for the mini guys.
I can ask him for some details if you wanna get in touch n see if he can help you out? I know he's into mini's, but a dizzy is a dizzy and they're all made by similar companies and work in the same way.
Old May 24, 2012 | 07:47 AM
RS2000CUSTOM's Avatar
RS2000CUSTOM
A distributor ignition system is always going to be a compromise of the optimum timing that the engine requires.
Hence the reason for computer controlled engine management systems
But the short answer to your question is yes
Here is a distributor to which I have had the ignition curve modified to my own requirements
Old May 24, 2012 | 07:58 AM
RS2000CUSTOM
Sounds like you may have a broken or dislodged bob-weight spring
Old May 24, 2012 | 09:08 AM
durham fiesta
where can i get the advance curve changed to suit my engine ?
TPM961
Jan 15, 2018 10:50 AM
20/20 vision
Sep 29, 2015 11:27 AM
Benleys
Escort Range
Sep 28, 2015 01:56 PM
arfurski
Sep 26, 2015 10:39 AM
dms04
Sep 11, 2015 01:57 PM
