esc cos clocks???
Old Apr 20, 2004 | 01:34 PM
kjc300's Avatar
kjc300
Default esc cos clocks???
is there a permanant 12v feed to any instrument in the esc cos clocks??
I want to hard wire my act gauge to the clocks. It's easy to do if I only want the act on with the lights, which to be fair I do have on all the time. But should I not want the lights on!!! I cannot think of any + feed that would be a stable 12v's due to the nature of the gauges, apart from the lights!!
Old Apr 20, 2004 | 07:28 PM
Speedy G.'s Avatar
Speedy G.
That looks really really nice m8.
How did you put it in and what did you have to sacrifice???
Old Apr 20, 2004 | 07:38 PM
kjc300's Avatar
kjc300
Geert, I had a spare mk5 front bit so I used that, however a small amount of 'butchery' was required on the rear section. There is only plastic in the way - so I moved it to the bin!!
Old Apr 20, 2004 | 07:49 PM
Speedy G.'s Avatar
Speedy G.
Aren't there any lights in the way m8 that you had to get rid off?
It's been soo long since I drove my car so I really can't tell.
Old Apr 20, 2004 | 07:51 PM
kjc300's Avatar
kjc300
No!! The only ones up the top are the indicator one on the left and main beam on the right!!
Old Apr 20, 2004 | 07:57 PM
Speedy G.'s Avatar
Speedy G.
COOL. Wanna do mine aswell???
Old Apr 20, 2004 | 07:58 PM
kjc300's Avatar
kjc300
No, it's a tw@t!!!!!
Old Apr 20, 2004 | 08:00 PM
Speedy G.'s Avatar
Speedy G.
AHHHHHHH, come on, you KNOW you wanna m8.
Old Apr 20, 2004 | 08:24 PM
kjc300's Avatar
kjc300
Rough guide!! note these are my old mk5 clocks!!
The portion of plastic shown has to be removed, plus the top clip that holds the fuel/temp gauges in (there are two screws as well so no probs) you will have to remove the gauges to do it obviously. Be very careful removing them especially the EL connection!! Once out you can chop away!!
you also need a clearance hole as well, roughly here ish!!
measure and mark out front housing remembering that the gauge must sit above the temp/fuel gauge section!!
Just a bit of braveness required gents!!!!
Mark_
14
Jan 16, 2016 05:27 PM
cossie brad
Sep 29, 2015 02:38 PM
Mr S1
20
Sep 27, 2015 04:06 PM
`spotty
Sep 25, 2015 11:41 PM
