Omex help!!
Old May 6, 2012 | 11:28 AM
Shaunster's Avatar
Shaunster
Default Omex help!!
Finished wiring in my 600 and connected it to my laptop etc.
On the first start parameters have all reading properly apart from my crank position! No rpm when cranking, no spark, no fuel.
Have got a cossy sensor (vr type). So no jumpers on the main board. Showing 660 ohms through the sensor and between 1.8v and 1.3v when turning the engine over.
Set the crank position options to- lo gain above 2200, high gain below 1900, failing edge function and 50ms delay.
Still nothing, checked the wiring and the sensor connects to the right pin on the omex, read the manual (last resort) and still nothing!!
Any help would be wicked, omex are shut for the long weekend so I'm counting on you guys!
Cheers, Shaun
Old May 6, 2012 | 08:21 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
Check you have the correct "air gap" between crank sensor and timing trigger wheel or flywheel (depends on which trigger method use) ?
Old May 7, 2012 | 08:11 AM
Shaunster's Avatar
Shaunster
Got 0.584mm gap, done with a feeler gauge.
Like I said got 1.3 to 1.8v on cranking, is this right? What does everybody else get?
dombanks
Sep 21, 2015 08:38 PM
jay030787
Sep 18, 2015 07:34 PM
Tank Mike
Sep 14, 2015 03:56 PM
ekjim
Aug 17, 2015 08:57 PM
turbobill
Aug 9, 2015 05:21 PM
