Escort RS Turbo massive running problem please read!....totally stuck
Old Apr 29, 2012 | 08:29 PM
webbie227's Avatar
webbie227
A Webb
Default Escort RS Turbo massive running problem please read!....totally stuck
i have a Escort RS Turbo series 2 and wont run when you start it, it chucks out black smoke then stalls and is massivley over fueling
then if i unplug the plug at the rear of the metering unit with the black unit on (fuel pressure acuator) it runs absolutley fine
i have tried 2 other metering units and changed the wiring loom and its still the same!
im totally stuck and havn't a clue whats going on and what to do next?
i would carry on running with it unplugged but i know it gives you extra fuel when boost comes on so i don't want to run it lean so please what do i try next people??
Old Apr 30, 2012 | 11:13 PM
Stu @ M Developments's Avatar
PassionFords Creator
Black box is almost certainly the culprit here, assuming this is a new fault and hasnt been caused by building with a missmatch of parts.
Billy_RS
16
Oct 11, 2025 09:41 PM
kosienutter
31
Aug 22, 2015 09:55 AM
A.t.p
Aug 15, 2015 11:37 AM
turbobill
Aug 9, 2015 05:21 PM
adriansaleem
Aug 1, 2015 09:28 PM
