Blower not working on 1 and 2 - Focus MK2
Old Apr 28, 2012 | 12:17 PM
Rob Frain's Avatar
Rob Frain
Smile Blower not working on 1 and 2 - Focus MK2
Hi
Weird problem - the blower on my car seems to ghave stopped working on setting 1 and 2. 3 and 4 are working fine. Most people on here have said resistor pack if it only works on setting 4?
Anyone reckon its the resistor pack or should i be looking elsewhere?
Old Apr 28, 2012 | 12:19 PM
martysmartie's Avatar
martysmartie
They would be correct in saying so
Reason why it works on pos 4 is because that is direct live, i.e. full speed, hence the resistor pack is not required.
Martin
Old Apr 28, 2012 | 12:24 PM
Rob Frain's Avatar
Rob Frain
Sorry it works on 3 and 4 in the car! And there is a definite difference in speed between the two so it does appear to still be working on those - just nothing on 1 and 2 - and obviously 0!!
Old Apr 28, 2012 | 12:29 PM
martysmartie
Oh sorry, totally different then, I suspect the switch is faulty, so it may be worth checking the switch out, if it's working on 3 then the resistor pack is ok, of course the resistor pack could just have failed on those two postions, but it's unlikely, on MK1 it ALWAYS fails totally, hence no position 1-3.
When the MK1's burnt out resistor packs, the immediate cause is actually down to poorly fitted pollen filters, due to the position of them they would let water past into the heater motor IF they were not fitted correctly, which would cause it to sieze and cause resistance= burnt out resistor pack, don't hear of it really on the MK2's.
Martin
Old Apr 28, 2012 | 01:13 PM
ste1806's Avatar
ste1806
Mine was doing the same not working on 1 and 2 but working 3 and 4, changed the resistor pack all is well again.
Ford Finis Number - 1325972 fits Focus 2005 - 2011
Old May 2, 2012 | 06:39 PM
Rob Frain's Avatar
Rob Frain
Cheers guys all working now!
Old Aug 28, 2012 | 12:45 PM
RRJ's Avatar
RRJ
Default Where do I find the resistor pack
I have the same problem, not working on 1 or 2. I got a new resistor pack and went to fit it, but it does not seem to be behind the glove box. Is it in a different position for a Mk2 ?
Old Feb 20, 2013 | 03:25 PM
escort4door's Avatar
escort4door
Exclamation Blower on MK 2
There are two wires brown & red-brown & white coming from switch-they go to 2 spades at the top of the unit high up underneath brown & red on the left and brown & white on the right or the other way round.Hope this works I have rebuilt a mk2 completely so email gorticaw1952@hotmail.co.uk for help
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
