No power??? please help!!
Old Feb 28, 2005 | 12:58 PM
matts1's Avatar
matts1
Default No power??? please help!!
Hi all,
My sister is having problems with her Corsa and I know sod all about them.
It's spluttering and lacking power, no real go in it and it was ok a while back.
It's an L plate 1.4
The Head gasket has been done, new plugs, carb cleaned and mixture all set but still no power
Any ideas, she may sell it if she can't solve the problem.
Any help would be
Matt
Old Mar 1, 2005 | 11:52 AM
rich2302's Avatar
rich2302
did it have this problem before the head gasket was done.
Sounds like a timing issue to me, maybe the cambelt has slipped a tooth ?
Old Mar 1, 2005 | 12:02 PM
matts1's Avatar
matts1
Yes had the trouble before, will sit and idle but every few seconds it will miss a beat, seems to struggle at low revs and has no real go in it, like it's holding back, she also said changing up gears causes problems, as the revs drop in the higher gear the car starts to chug.
Wasn't sure if it would be something electrical like an air flow sensor or fule pump restricting the fuel or air??
Old Mar 4, 2005 | 08:26 PM
whale tail's Avatar
whale tail
i had a nova like that once , it had a vacuum leak and was sucking in too much air, u could also try changing the fuel filter
Old Mar 5, 2005 | 02:03 PM
K18NEO's Avatar
K18NEO
coil
dizzy
Old Mar 5, 2005 | 04:32 PM
matts1's Avatar
matts1
Whail Tale, you could be onto to something there, the air feed pipe from the air box to the front of the car is a really bad fit and has been teped before, I will re seal the area and see if it picks up.
Will keep you posted.
Old Mar 10, 2005 | 08:59 AM
matts1's Avatar
matts1
Yep, cold air feeder pipe not fitted properly, fitted it nice and tight and power has returned.
Cheers people
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
