hego sensor and power steering switch???????
Old Apr 22, 2012 | 08:45 PM
16vzetec's Avatar
16vzetec
Default hego sensor and power steering switch???????
my mk4 escort 2.0 zetec runs on rs2000mk5 management.
i currently run 1 hego sensor and car runs quite well but im sure it cant be spot on.
i have a wiring diagram here and it says that each sensor has 1 seperate pin each in the ecu.
if you unplug 1 sensor does it sense of the other sensor and use that reading?
or can i wire the two together?
i only have 1 hego hole and cant get another one welded in without alot of agro.
also can i short circuit the power steering switch so it revs the engine higher all the time on tickover?
need higher tickover for my setup
DixieTheKid
11
Jun 6, 2020 11:20 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
