Abs Conversion
Old Mar 20, 2012 | 07:15 AM
V6 POWER JUNKIE's Avatar
V6 POWER JUNKIE
Default Abs Conversion
Hi, I'm changing to this ABS Conversion off a 2WD, but ive
got a 4x4 wiring harness, & its going on my XR4i. I'm not using the ECU or the ABS itself,
I'm now left with 2plugs on top of the reservoir, & 3 plugs on the unit itself,
Please can anyone tell me how do I wire this up?
1000 Thanx
Gaf
Old Mar 20, 2012 | 02:03 PM
V6 POWER JUNKIE
Little update, I've traced back & cut the abs sensors out now,
all the wires from the ecu ive trimmed back, there is some
Obvious live & earths I gotta join up & ive worked out the top
of the resevoir wires, so I'm only real stuck now on what do I
do with the power for the motor with the 2 pin plug, & the 2
Solonoids, 1 got 2wires, I got 5?
P.S. like I said I only want it for assistance only.
Thanx G
Old Mar 27, 2012 | 03:16 PM
V6 POWER JUNKIE
Sorted now thanx!!
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
