oil breather
Old Apr 18, 2004 | 01:47 PM
righthooker's Avatar
righthooker
Default oil breather
For some reaso unknown to me the oil breather system on my cossie is conected in at the head but when i follow it down it is not conected at the bottom (block or sump )cant see a conection for it . either it aint been conected up properly last year after gasket fitment or it nrever was and was just bolted on for looks
thing is will this just make the oil piss out as i have been runing it like this for ages and it dont realy use tht much oil wierd. So where should the bottom pipe be attached anyhow
Old Apr 21, 2004 | 06:29 PM
ML's Avatar
ML
There is a union that fits into block, what breather is it anyway?
Matt
Old Apr 21, 2004 | 07:20 PM
Fast Guy's Avatar
Fast Guy
Should it go to the inlet pipe somewhere?
It might be a cheap mod.
At least I put my pipe into a catch tank on my last car when I took the breather off the inlet end.
Old Apr 21, 2004 | 09:42 PM
So how should these connect up? I just brought a secondhand Spec R breather and would like some pointers if poss
Old Apr 21, 2004 | 10:34 PM
Have u bought one with 3 outlets or 4?
Paul T
Old Apr 22, 2004 | 01:13 PM
Dave Henshall's Avatar
Dave Henshall
have a look in here at mine ...... https://passionford.com/forum/viewto...919&highlight=
Old Apr 22, 2004 | 06:13 PM
Not sure I havent got it yet, looks like its got three from the pics ive seen.
Thanks for the link Dave, if mine only has three i was going to take one from the rocker, and one from the standard left hand breather.. Hang on what do i do with the other Didnt really want to mess with the right hand blanked side as i dont want to strip eveything away if poss..
Old Apr 22, 2004 | 06:18 PM
Just found out it has four
Old Apr 22, 2004 | 09:01 PM
Dave Henshall
have another look on the link, ive added another 2 penneth worth
as a matter of fact the RHS (under the turbo) block adaoptor is much easier to fit than removing the facotry breather system with the head still attached - i suppose i had it easy with it all in bits so took full advantsge of the fact and did as much as i could with it in that state.
Old Apr 23, 2004 | 10:09 PM
Thanks for the tips Dave very useful, Does anyone know where i can buy a fitting kit with all the adaptors ect? I also need some blue hosing. BTW do you have to worry about the heat with the tubing near the manifold & turbo?
Old Apr 26, 2004 | 01:10 PM
Dave Henshall
yep - i wrapped the piping under the turbo side in some self adhesive silver foil wrap
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
