Cortina P100 diff swap
Old Mar 6, 2012 | 07:06 PM
V8hotrodboy's Avatar
V8hotrodboy
Default Cortina P100 diff swap
Hi, as you can tell im a newbe to this site so please go easy! Im an ex mechanic from Kent and still play around with cars, my current toy is a 1932 Ford Hot Rod with a V8 Rover engine and auto box. But the rear axle is from an early Cortina based P100, which is where my problem starts, or finnishes as the rest for the car is now sorted. Ive had the car for around 6 years but reacently fitted some lower profile rear tyres which have thrown the gearing way out as its a 4.6 cwp ratio. I want to fit a 3.09 from a Capri, but the firm thats fitting it are having a problem with the bearing size. The ones in my casing are smaller than the Capri unit so dont fit. Is it possible to machine out the diff casing to except the bigger Capri ones? Its not an option to fit a Capri axle as the P100 one is modified with extra brackets etc to fit my car, also its 5 stud not 4.
Lots to ask i know but cant seem to find the answer. Thanks for your help.
Old Jan 30, 2019 | 05:16 PM
RDStaple's Avatar
RDStaple
I know this is resurrecting an old thread but did you ever sort this? I have what I believe is a Cortina P100 axle in my roadster and the ratio is geared way too high. I can't seem to find much info atall on diff swaps in these axles
Ian1964
12
Jan 26, 2021 11:57 AM
Iain Mac
Sep 30, 2015 09:39 PM
20/20 vision
Sep 29, 2015 11:27 AM
DavidK
Sep 27, 2015 02:55 PM
grishenko45
Sep 9, 2015 12:58 PM
