is a bleed valve a bad idea
Old Feb 25, 2012 | 05:00 PM
CHUNKYS RS's Avatar
CHUNKYS RS
Default is a bleed valve a bad idea
i have a cosworth 4x4 and the amal valve is broken so until i get another i have fitted a bleed valve and set it to 17psi
a friend of mine told me this was a very bad idea and would affect the way it comes on boost is this true
i do intend to get another amal but though solong as i set the boost and leave it then it would be ok i understand that the ecu can no longer cut the boost if there is a problem
any more info would be good
Old Feb 25, 2012 | 11:43 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Basic form of boost control. Im sure the ecu would cut the boost as the bleed valve just bleeds off air and when the ecu sees the required amount to cut off it will do so. But the more you open the valve the more air it will bleed off so the boost the turbo produces will be higher and will be going into the engine and you'll end up running lean and melting. I think if you have to use one and can be trusted to leave it alone once set then you'll be ok. What was your car set to run boost wise before the amal failed? Best bet is to get on ebay or reputable breakers and get another amal valve
Rsmat
63
Sep 25, 2015 12:11 PM
skypeller
Sep 19, 2015 09:58 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Harryh24
23
Aug 24, 2015 09:07 AM
jay030787
Aug 17, 2015 06:16 PM
