Erst fuel pump
Old Feb 25, 2012 | 09:50 AM
DALE 77's Avatar
DALE 77
Default Erst fuel pump
Hi folks, do these pre fuel pump filters work?
i think my bosch pump is dying as on top end its leaning off.
Voltage to the pump is fine.
Think it my have rust in it from the tank.
Old Feb 25, 2012 | 03:35 PM
martysmartie's Avatar
martysmartie
Has the filter been changed recently?
No, what you have is x power at the pump at the point where you tested it, likely to be when idleing?
It's when the pump is load it can not always get the power it needs due to old wiring, I am not sure if this weak point applies to ERST but it is a weak point on Cosworths!
It of course might be something unrelated.
Martin
Old Feb 25, 2012 | 05:17 PM
DALE 77's Avatar
DALE 77
Martin
Pump (uprated bosch) & filter(genuine) has done a 1000 miles, then went for a set up on the rollers.
The car was going lean on top end thats when they checked the pump
but all was good. I think there may be crap in the system, i was just going to
replace the pump & filter again thats when i came across those pre fuel pump
filters but dont know if there any good/work.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
