No Spark on a cossie
Old Feb 17, 2012 | 07:40 PM
Gary @ RS CLASSICS's Avatar
Gary @ RS CLASSICS
Former Sponsor
Default No Spark on a cossie
i have no spark from the coil
I take the coil lead of the dizzy and put it to earth: when you turn the key to the ignition on there is a spark. When cranking the engine no spark
Any ideas lads???!!!!
Old Feb 17, 2012 | 07:53 PM
daz1968's Avatar
daz1968
Check phase sensor and crank sensor first they are usual culprits
Old Feb 17, 2012 | 07:54 PM
J1mbo's Avatar
J1mbo
B1mbo
If you have a cap from the coil to the cap but nothing the other side of the cap then I'd say try swapping the cap for another
Old Feb 17, 2012 | 07:59 PM
Gary @ RS CLASSICS
Former Sponsor
when the lead is off the cap (coil lead to cap) there is a spark when the key is turned to ignition lights. When crranking the engine over there is no park from the lead
Old Feb 17, 2012 | 08:01 PM
Gary @ RS CLASSICS
Former Sponsor
i have just got this car in and it has not been started for 3 years. full service today plugs etc. if the guy before put the CPS and the Phase sensor plug the wrong way round would this cause the problem
if not what would be the symptom
Old Feb 17, 2012 | 08:03 PM
Gary @ RS CLASSICS
Former Sponsor
tried CPS no change: tried different ECU no change
Old Feb 17, 2012 | 08:05 PM
J1mbo's Avatar
J1mbo
B1mbo
Try cap Gary, like I say, you have spark going in but not coming out, worth a punt.
Ps, did you see if you had them trim bits?
Old Feb 17, 2012 | 08:06 PM
Gary @ RS CLASSICS
Former Sponsor
sent you a pm
Old Feb 17, 2012 | 08:11 PM
martysmartie's Avatar
martysmartie
Don't think it's the cap, as that would not prevent it sparking whilst it's turning over.
Maybe the coil itself or possibly the amp?
Martin
Old Feb 17, 2012 | 08:34 PM
Gary @ RS CLASSICS
Former Sponsor
cheers mate for your advice on the phone and i will give it all a try tomorrow and i will let you know
Old Feb 17, 2012 | 08:35 PM
Gary @ RS CLASSICS
Former Sponsor
cheers martin will have another go tomorrow on it
Old Feb 17, 2012 | 10:19 PM
J1mbo's Avatar
J1mbo
B1mbo
No worries Gary fingers crossed mate, hopefully just be something small
Old Feb 17, 2012 | 10:20 PM
J1mbo's Avatar
J1mbo
B1mbo
Martin
Hi martin, after speaking with Gary we've ruled out dizzy cap, I believed he had a spark from the coil when cranking but he dosnt
Old Feb 18, 2012 | 07:17 PM
Gary @ RS CLASSICS
Former Sponsor
problem solved thanks for your help everyone
Old Feb 18, 2012 | 07:39 PM
JamesH's Avatar
JamesH
What was the problem in the end?
Old Feb 18, 2012 | 07:41 PM
COLEYST200's Avatar
COLEYST200
so wot was it then mate
Old Feb 18, 2012 | 08:38 PM
Gary @ RS CLASSICS
Former Sponsor
the guy i got the car from had plugged the CPS plug in to the Dizzy and the Dizzy plug into the CPS.
swapped this morning and fired up straight away. Problem was the plugs are both black so i checked the wire colours on another loom i had
Old Feb 19, 2012 | 10:31 AM
martysmartie
Glad it's sorted, common mistake is that.
Martin
Old Feb 19, 2012 | 06:04 PM
Gary @ RS CLASSICS
Former Sponsor
So am I mate
Old Feb 19, 2012 | 06:52 PM
Mungus's Avatar
Mungus
Really strange, I got exactly the same problem tonight.
Ran the car, took it around the block, parked it back on the drive for a wash, wouldnt start after.
Exactly the same issue.... the coil lead will arc when put to earth as soon the ignition is on, but wont spark when turning over
I thought it was the group A coil which had died. Havent messed with any CPS/Dizzy.... could someone post how they should be please??
Thanks
Huw
Old Feb 19, 2012 | 06:54 PM
martysmartie
All it is, the CPS and phase have the same connectors and physically can be interconnected to each other by mistake, this won't be your issue, as you say you haven't touched anything!
Maybe ignition amp?
Martin
Old Feb 19, 2012 | 07:00 PM
Mungus's Avatar
Mungus
Just looked at mine ... I have a black lead and black plug going to the dizzy and a black lead with white plug going to a sensor at the side of the oil filter.
Is this the CPS?
Is mine right?
Huw
Old Feb 19, 2012 | 07:01 PM
Mungus's Avatar
Mungus
Maybe ignition amp?
Martin
Possible I suppose... any way of testing?
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
