Fiesta Mk6 Starting problem,
Old Feb 20, 2012 | 10:08 AM
ADT168's Avatar
ADT168
Default Fiesta Mk6 Starting problem,
Hi People,
I have a 53 plate, Ford Fiesta 1.4 Duratic petrol 63,000 miles,
Just recently When i go to start the car from Cold, the car will not idle just dies, If you hold the throttle on it will idle ok, The car does not run lumpy or anything,
Once the car is warm it can be started perfectly with no trouble at all,
I have had the car plugged in to a diagnostic machine (No Fault Codes)
I have removed the throttle bodie and cleaned it with Carb Cleaner,
I have Cleaned The Maf/Map sensor with Carb Cleaner. (Still the same),
I serviced the car not long ago oil,air,fuel filters, pattern filters, i didnt change the spark plugs,
I dont Know what to do with it Next ?
Has anyone else had this Problem, And have they found the cure?
Thanks people
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
