Transit RWD 06 cutting out
Old Feb 16, 2012 | 08:29 PM
Kylejm's Avatar
Kylejm
Default Transit RWD 06 cutting out
Hey folks new to this so go easy, I've got a 2006 RWD transit in my garage at the moment that randomly cuts out whilst driving and the dash lights up, dials stop working and "-------" just appears where the mileage normally shows.
Tried plugging my snap on diagnostic computer in to no avail it tell me no vehicle power detected and the dash again plays its tricks with the dials etc.
I've inspected all wiring at fuel pump fuse box and ECU all fine so kind of stuck now, without reading the trouble codes it's making things difficult has anybody had this problem and can help me out, would appreciate it.
Old Feb 16, 2012 | 08:50 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Mk6 or mk7?
First port of call if it's a mk7 would be the key but if it's a mk6 then I'm not so sure
Have you asked on www.fordtransit.org ?
Old Feb 16, 2012 | 08:57 PM
Kylejm's Avatar
Kylejm
It's a mark 7 I think the one with the gear lever on the dash apose to on the floor and has the all blue key fob if that helps lol, what did you mean by it will be the key?
Old Feb 17, 2012 | 09:18 PM
steve4i's Avatar
steve4i
the mk6 were bad for loosing memory too the key. what's the temprature like is it only cutting out when it get's hot? if so they have a fail safe when the water pump is faulty so it doesnt over heat and cook the engine.
Old Feb 17, 2012 | 10:20 PM
Kylejm's Avatar
Kylejm
Well it's defo a mark 7 steve and to answer your question yeah it usually only cuts out when the engine is warm but temp gauge is at normal,
I've cured the fault with my diagnostic computer not connecting by finding a blown 10 amp fuse behind the glove box for the OBII connector, got a trouble code which was P2265- water in fuel sensor circuit range/performance. Signal plausibility failure. Current DTC.
So with this new info I replaced the fuel filter (not much water in fuel though) and reset the button on top and gave it a 15 mile road test all was well and I thought I had cured it until driving back to the workshop it lost power and the dash reading that normally tells you the distance left till it needs more fuel just read "----" so I stopped the engine then restarted it and all was fine but keeps doing this intermittently 😁.
Any more help would be great lads because I just need this van out my workshop now
Old Jan 1, 2015 | 10:41 AM
beanmasteruk's Avatar
beanmasteruk
Did you solve this?mi have exact same issue!
Old Apr 19, 2022 | 11:53 AM
manchesterpirateboat's Avatar
Default Same
have you found the problem as mine is doing the same ? Thanks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
Fudgey
21
Sep 30, 2015 06:19 PM
