cold starting problem on the wifes car, help please
Old Feb 4, 2012 | 03:51 PM
addi monster's Avatar
addi monster
Default cold starting problem on the wifes car, help please
hi all , i bought the wife a 2004 KA with the 1.4 duratec petrol engine, when its warm it starts 1st time but recently its being a pain to start it when its cold, it turns over for ages before firing, also it has a slight missfire, any ideas guys, cheers
Old Feb 4, 2012 | 05:49 PM
addi monster
btt, any help guys,.,.
Old Feb 4, 2012 | 08:14 PM
oldford's Avatar
oldford
Is your MIL (EML) on? Then have the codes read.
How is the engine running cold? Is the engine hunting at idle?
Do you hear the fuel pump when you switch the ignition on?
If yes, then wait 2 seconds before starting.
If no, start engine briefly (1-2 seconds), switch off and try again.
Old Feb 4, 2012 | 08:21 PM
addi monster
hi, the pump primes ok, the car does hunt from time to time, there is no lights on the dash (eml ect),, would this be the ect sender,.
Old Feb 5, 2012 | 08:58 AM
oldford's Avatar
oldford
Hunting at cold idle suggest a lean mixture. The hunting disappears when the engine warms up (and the oxygen sensor start to work)?
Could be a defective/ageing sensor (like ect or act) or some air leak.
Fuel pressure a bit low is another possibility.
Check all vacuüm connections around the inlet manifold for leaks/cracks.
Then have the sensors checked at cold engine.
Old Feb 5, 2012 | 10:31 AM
addi monster
tbh i reckon it is the ect sensor, it all ads up with the faults and symptoms of a failing ect so i will get one asap,
steve
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Archiejay
Aug 12, 2015 12:07 PM
Zoggon
Aug 10, 2015 10:39 AM
Sjieter
Aug 5, 2015 09:47 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
