Fiesta rs turbo 1991 car holding back at about 90mph
One Mad RS Nut
Hi all i have a problem with my fiesta rs turbo 1991 it had chip beigh injectors t3 turbo not sure what boost i am running but i think its only about 10psi the rest of the engine is standard as far as i know the cam could be standard ,it seam's to be holding back the higher my speed increases ive only been able to get 90mph and it just seams to be stone walling by then !!
If any body can advize on what could be the problem i would be greatful
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
One Mad RS Nut
Hi guy's thank you.![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
There is a few things i was wonder mite not help the speed sensor is missing on the gearbox was wonder if that would not help and i think some of the wiring could be suspect ive already had to rewire the battery terminals ,the other is it's not got the amal valve connected its got a bleed valve connected ,will take what you have said under advice thanks,one of my job's i need to sort is my gearbox oil leak and slit engine oil leak then can think about takeing it some where to have it looked !!
The trouble of owning any Fast Ford or indeed any performance car is bodging, either due to owners not knowing what they are doing, or doing thing on the cheap.
Wiring problems are most common as many have had audio equipment along with various alarm systems etc being fitted over time.
The bleed valves are a bad idea imo as it can actually do less than the standard electronic boost controller can, the other danger is meddling fingers with the temptation to "tweak" them and you will have a meltdown.
There can be no substitute for a setup as not only will be running at it's best you will also know this too.
Yes not having the speed sensor will also cause problems, although I am not convinced it would cause your particular issue, sounds more fuel/ignition related to me.
Martin
Martin
One Mad RS Nut
hi yes i totaly agree after fun i had with my last car not going to make the same mistake again will get it looked at will check some of the wiring my self as i am a sparky any way just so i am not paying for some body else to fix simple wiring problems .
some of the earths don't look that good but it does start first time every time so thats good .
and then ive just had a new alarm for insurance robbing buggers so notthing to worry there i removed the other one my self it wasn't very good .
but there are a few suspet wires and earths that could do with being better ,the idle isn;t very good some day's its ok the another day it just cut's with no warning so this could be idle valve but could just be a bad connector as well ..
you said about fueling and ignition ive not touch plugs becuase decided if its runing and not missfiring or anthing like that i will leave them i will only get my dad moaning at me for touching them![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
but was thinking fue to the fact its got bigger injectors he the last owner did say he had had problems with the fuel pump and was wodner if he's gone and removed the one fitted for the bigger injectors if it ever had one for a normal pump that wouldn't help iam thinking but with me not having paper work for some things that the car has had done who now's![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
you was saying about bodge yes its had some of that defo like it had a block of wood wedged between the sump and alternator that was my first job sort that out![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
any way yes will think about takeing it for a setup and check thing out asap when funds permit thanks glyn
JoeyBoyden
04-01-2024 02:36 PM
vdun01
Ford Fiesta
05-10-2017 08:14 AM
