03 1.8 TDCI flashing glow plug light - not the same as the other threads :)
Old Jan 27, 2012 | 01:25 PM
joeyjoejoe206's Avatar
joeyjoejoe206
Default 03 1.8 TDCI flashing glow plug light - not the same as the other threads :)
Hi All,
I realise this is a common fault and have read previous threads on this, but non seem to display the exact same problems as mine. I will get my diagnostics read when i can get the car back to the garage a bought it from (50miles away - and he isnt working weekends until Feb) so until then I was looking for help.
The fault:
occasionally engine glow plug flashes and car goes into limp home mode after approx 4 miles (always happens within the first 5-10 minutes of a journey if its going to happen)
The fault NEVER happens twice on a journey
The car does not cut out, just limp home mode, and always restarts fine - i just dip clutch and restart the engine to clear the problem.
The throttle responds fine, the engine pulls well and idles as it should when running.
Current list of potential fixes:
cam + cranks sensors replaced for the newer models (by garage before i bought it)
fuel filter changed
cam sensor cleaned
battery earths cleaned
I find this different to other failures as its so consitent in happening at the start of a journey and never happens twice, which leads me to believe its not as sinister as a fuel problem, and more likely electric
once again, I appreciate a diagnostics check may shine more light on the situation, but I am not paying for this to be done as it will be done by the garage I bought the car from once I can get there. Just wondered if there was any other cheap fixes I might be missing
Thanks
Joe
Last edited by joeyjoejoe206; Jan 27, 2012 at 01:42 PM. Reason: forgot to mention it always restarts fine 100% of the time
Old Feb 4, 2012 | 03:27 PM
joeyjoejoe206
no responses? i thought this was one of the most common failures on diesels??
I changed the fuel filter - but that didnt nothing, still happening on about 20% of journeys
Old Feb 5, 2012 | 01:01 AM
steve4i's Avatar
steve4i
has it had the better live voltage too the camshaft sensor? as they suffer problems due too low voltage
Old Feb 10, 2012 | 11:37 AM
joeyjoejoe206
yes, it has 2 new grey sensors for the cam and crank.
I am having the fault code read on saturday so i hope to get somewhere. It is still happeneing on about 40% of journeys
Old Feb 21, 2012 | 07:58 AM
joeyjoejoe206
Well,
I thought I would add an update to this in the hope that it benefits someone else.
I had the codes read and p0251 was the error. I was told this could be due to a number of things, e.g aftermarket filter or fuel metering valve failure.
Before I started shelling out, i thought i would try the easy fixes, so i removed the fuel metering valve, and cleaned it in carb cleaner (there was no visible dirt), before cleaning the electrical connectors on the loom and the valve.
After putting it back in and 500 miles later, I have had no repeat of my flashing glow plug problems
fingers crossed thats the end of it
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Alun Gregory
Sep 6, 2015 09:40 AM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
