escort mk6 barrel problem
Old Jan 25, 2012 | 07:59 PM
sunchman1's Avatar
sunchman1
Default escort mk6 barrel problem
Hi people.
The key for my '97 ghia x escort no longer unlocks my drivers door. It unlocks fine and works the other side unlock/lock and works the central locking fine.
Just want a pointer as to how to repair. dn't need any more headaches.
Thanks.
Adam.
Old Jan 25, 2012 | 08:20 PM
daz-cos's Avatar
daz-cos
Could u not just swap the driver and passenger locks over? Not sure if they're the same?
Old Jan 25, 2012 | 08:23 PM
lordjc's Avatar
lordjc
Lock repair kit? Often on ebay or from ford,
I'd fit remote central locking so you never have to use them!
Old Jan 25, 2012 | 08:32 PM
sunchman1's Avatar
sunchman1
yeah possibly daz. Will have a look 2moro.... is fitting RCL a long job? Got a list of other things to do aswell but sounds like a good improvement
Old Jan 25, 2012 | 08:33 PM
sunchman1's Avatar
sunchman1
thanks guy's
Old Jan 25, 2012 | 08:35 PM
r.s.2000 ginger's Avatar
r.s.2000 ginger
Spray some wd40 in it my drivers side lock was the same and some times couldnt open it or lock it and after two years i sprayed wd in it and its like new. I was just about to get a new lock set but no need now.
Old Jan 25, 2012 | 09:24 PM
sunchman1's Avatar
sunchman1
Strangely not tired that yet.......... Will give it a squirt in the morning for a laugh. If not will look for a replacement lock or repair kit
Cheers.
Old Jan 25, 2012 | 09:34 PM
r.s.2000 ginger
Spray it right in the lock with the starw that comes with the tin. Hope it does the job.
Old Jan 27, 2012 | 07:41 PM
r.s.2000 ginger
Did you try spraying wd40 in your locks after mate.
Old Jan 27, 2012 | 07:43 PM
Jumby's Avatar
Jumby
Bit different.
I had the EXACT same problem...eventually none of my locks opened except the boot, i brought new locks off ebay for like a tenner, only took an hour to put em all in
Vincereese
Jun 1, 2023 09:14 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
