Problem with Ford Connect Van Starting
Old Jan 23, 2012 | 10:43 AM
scottymully's Avatar
scottymully
Thumbs down Problem with Ford Connect Van Starting
Hi all,
my 12v socket fuse blew the other day. So today i changed it with a new one. It now works but the van will not start. When i turn the key i get absolutely nothing, no noise whatsoever! all that happens is the immobiliser light starts flashing furiously??
it is not a problem with the battery as i can still turn radio/heater/lights on etc...
also i can still ock/unlock doors with key, but just cant get the engine to start!! please help! i am stuck at work if i cant get it to start.
Old Jan 23, 2012 | 10:58 AM
pani_k's Avatar
pani_k
PassionFORD Member
Pull the fuse out and see if it starts?
Old Jan 23, 2012 | 11:04 AM
scottymully
how will that solve the issue? could the fuse stop it starting
Old Jan 23, 2012 | 11:07 AM
pani_k's Avatar
pani_k
PassionFORD Member
I don't know but if it was fine before, you changed the fuse and now it won't start it won't hurt to pull it out.
Old Jan 23, 2012 | 11:13 AM
scottymully
just tried no luck, think it might be immobiliser problem, immobiliser light flashes constantly when key is turned
Old Jan 23, 2012 | 12:17 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there is also a fuse for the starter under the bonnet somewhere
we've had this issue with one of our vans and it was the fuse with a dodgy contact
Dr. Ickxs
Aug 15, 2015 11:34 AM
Sjieter
Aug 5, 2015 09:47 PM
vdubo7
Aug 2, 2015 08:17 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
