ka engine
Old Jan 22, 2012 | 04:15 PM
benchant's Avatar
benchant
Default ka engine
hi could anyone tell me if a ford ka engine will fit into a puma if its possible and what is involved in doing it
many thanks
Old Jan 22, 2012 | 04:26 PM
martysmartie's Avatar
martysmartie
Can't see why you would want to change from a Zetec engine to a old Kent (Endura-E) engine.
Martin
Old Jan 22, 2012 | 04:31 PM
CBenno's Avatar
CBenno
Why would you want a ka engine in a puma?
benchant's Avatar
benchant
im doing a project mate doesnt have to be a ka engine aslong as its a ford 1.4 engine and the inlet manifold is at the back not the front
Old Jan 22, 2012 | 04:32 PM
CBenno's Avatar
CBenno
A 2 litre zetec fits
Old Jan 22, 2012 | 04:35 PM
benchant's Avatar
benchant
gota be a 1.4 bud
Old Jan 22, 2012 | 04:36 PM
CBenno's Avatar
CBenno
The ka motor is a 1.3
Old Jan 22, 2012 | 04:39 PM
Ben26's Avatar
Ben26
this tread is such a fail , PMSL
Old Jan 22, 2012 | 04:40 PM
benchant's Avatar
benchant
ok 1.3 to 1.4 will the ka one fit do u know or any other engine that is 1.3 or 1.4
Old Jan 22, 2012 | 04:45 PM
benchant's Avatar
benchant
[quote=Ben26;5779867]this tread is such a fail , PMSL[/quo
while your on the taking the piss mode its thread not TREAD all im asking for is a bit of help with a project im doing
Old Jan 22, 2012 | 04:46 PM
CBenno's Avatar
CBenno
Just wondering how come you need the inlet at the back?
Old Jan 22, 2012 | 04:49 PM
benchant's Avatar
benchant
whatever engine i use will be going on carbs and i dont want the bonnet vent at the front
Old Jan 22, 2012 | 04:52 PM
CBenno's Avatar
CBenno
Couldn't you put the bonnet vent at the back and duct it under the bonnet to the front?
Old Jan 22, 2012 | 04:56 PM
deano2690's Avatar
deano2690
if your intent on a ka motor why not use the 1.6 out of the sport?
Still om unsure why you would not just carb the engine that came in the puma?
Old Jan 22, 2012 | 04:58 PM
benchant's Avatar
benchant
could do but my brother in-law wants to do it his way as its both of our project i just do all the fiberglass and filler and paint he does the rest just wana know what engine would fit really theres gota be one
Old Jan 22, 2012 | 05:01 PM
benchant's Avatar
benchant
not being rude mate but if you read the thread i did say its gota be
1.3 or 1.4 with the inlet manifold at the back
Old Jan 22, 2012 | 05:07 PM
deano2690's Avatar
deano2690
yea i got that bit but why on earth would you want to put an old endura OHV engine in a puma?
Old Jan 22, 2012 | 05:10 PM
deano2690's Avatar
deano2690
and the satndard puma engine has the inlet at the back if i am not mistaken (1.4,1.6 ) so why not use the 1.4 zetec?
Old Jan 22, 2012 | 05:11 PM
CBenno's Avatar
CBenno
Use the 1.4 puma zetec motor and try and convince your brother in law that the ducted bonnet is the right way to go! Then at least you will have a decent motor in it.
Old Jan 22, 2012 | 05:13 PM
CBenno's Avatar
CBenno
and the satndard puma engine has the inlet at the back if i am not mistaken (1.4,1.6 or 1.7) so why not use the 1.4 zetec?
Nope all the puma engines have the inlet manfold on the front even the FRP
Old Jan 22, 2012 | 05:14 PM
martysmartie
As said the Puma has is avaliable with the 1.4 (Zetec-SE) engine.
No it dosen't, inlet will be at the front on all the Puma's and will also be plastic.
Martin
Old Jan 22, 2012 | 05:15 PM
benchant's Avatar
benchant
i was just about to say the 1.4 puma i got inlet manifold is at the front
Old Jan 22, 2012 | 05:18 PM
deano2690's Avatar
deano2690
yea my bad
Old Jan 26, 2012 | 07:33 AM
Hobomassiv's Avatar
Hobomassiv
event he sportka 1.6 is only 95~bhp , the 1.3 duratec is 70-75, the older endura engine is about 60 or less!
Put a 2.0 zetec in it.
If it has to be a 1.3/1.4 i dont see the point and i would say save your money.
Old Jan 27, 2012 | 07:52 AM
Churtz's Avatar
Churtz
To answer the question u asked, yes it will fit. The gearbox casing is the same, so that takes car of the 2 mounts on that side. You will need to use the 1.3 engine mount for the off side. Worst case will need a little nodding on the drivers engine mount.
Matt
Old Jan 27, 2012 | 07:53 AM
Churtz's Avatar
Churtz
Modding**
Stupid iPhone. Ha
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
