RS Turbo oil smell on boost?!
RS Doer!!!!
Hi.
My S2 has a dump valve on and also an in car adjustable boost.
When the car boosts with it wound in, all is fine... but when you wind out the boost, it smells of burning oil and is very strong.... Could this mean turbo needs replacing and where would the fumes be coming from because as I say, when woun in using hardly any boost it is fine...
CheeRS, Paul
CheeRS, Paul
struggling with reality
This sounds like there is a prob with the oil seals on your turbo - the more boost you have, the more latteral foce there is on the spindle. This is why turbo setups for lots of boost use 360 degree thrust bearings! Turbo technics are suposed to be very good - when I worked at Garret they were the ones commonly referenced. They are NOT cheap though!
This sounds like there is a prob with the oil seals on your turbo - the more boost you have the more latteral foce there is on the spindle. this is why turbo setup for lots of boost use 360 degree thrust bearings! Turbo technics are suposed to be very good - when I worked at garret they were the ones commonly referenced. Thet are NOT cheap though!
RS Doer!!!!
I am looking at a couple of stage 1 and 2 turbos on ebay as mine is s1 turbo so not water cooled and my car is s2.... So was going to change in near future anyway.. Is there much benefit to having a stage 1 or 2? I have low comp mahle pistons you see...
Thanks for reply. Paul.
Not entirely sane
Have a look at the breather system, the higher the boost, the more blow by gasses going into the crank case. This has to go out through the breather system. If you aren't seeing smoke out of the exhaust then the turbo seals are unlikely to be a problem.
RS Doer!!!!
Right... so clean out the breather hoses etc? I have a baileys oil seperator on it if it sheds any light?!
I have been told to take off intercooler hose and see if excess oil in that as that will also be an indication to whether breathing system or turbo....
The turbo on it looks like any other but doesnt have the metal pipe coming from it which circulates the water round the system which has a pipe from the hoses for it - my pipe is currently blocked off.....
RS Doer!!!!
oh, as regards smoke out of the exhaust, have been old it has black smoke coming out once in a while but put that down to needing setting up! Thought if turbo was shot it would be blue coloured smoke? or am I wrong?!
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
CrOwSoN15
18
22-08-2015 10:24 PM
Escortdriver1
31-07-2015 02:36 PM
