slipping ap clutch
Old Dec 5, 2011 | 12:45 PM
rst-ste's Avatar
rst-ste
Default slipping ap clutch
I fit an ap-racing cp2000-8 clutch kit to my erst when rebuilding the engine.
I've just put my foot down for the first time after running in and the clutch slips on boost (anything over half a bar).
I got the kit from Burtons, has anyone else had this problem?
Old Dec 5, 2011 | 04:46 PM
lees rs's Avatar
lees rs
The Shed
Im having the same problem i fitted a heavy duty clutch to my rs turbo cab and im having the same problem it slips when the boost kicks in.One thing i never did is i didnt fit the spacer plate bewteen the engine and gearbox i dont no if this has any thing to do with it slipping have u fitted it on yours?,I no the clutch pedal can cause problems there is a self adjuster on the pedal and if the teeth are worn it could make your clutch slip u can buy one off ebay its worth a try mate
Old Dec 6, 2011 | 07:00 AM
rst-ste's Avatar
rst-ste
Hi thanks for your reply.
Mine didnt have a spacer plate on before and it didnt slip then. I did have problems with the clutch ratchet, it wouldnt go into gear so i fit a mk5 pedal. Not sure why its slipping with a better clutch system on
Old Dec 8, 2011 | 08:06 AM
rst-ste's Avatar
rst-ste
I lifted the clutch pedal with my foot, accelerated and there was no clutch slip! I have conneced the spring between the mk5 pedal arm and pedal box, could this be the problem?
Thanks
Ste
Old Dec 8, 2011 | 08:19 AM
fogulbennett's Avatar
fogulbennett
yea that most likey your problem but also check that you have put the cable thru the correct hole in the box other wise it will stretch the cable causing the clutch to slip im sure it has to be in the outside hole the one closest to the n/s! also when you put the clutch cable on did u have to lever the arm back?
Old Dec 8, 2011 | 09:32 AM
rst-ste's Avatar
rst-ste
I wasnt aware there was 2 holes, i'll have to check this at the weekend.
Yeah, i had to lever the arm back to get the cable on...is that right?
Thaks
Ste
Old Dec 8, 2011 | 09:17 PM
fogulbennett
no u shouldnt have too, uve prob got cable in wrong hole mate
Old Dec 8, 2011 | 10:19 PM
GVK.'s Avatar
GVK.
Tried adjusting the pedal so the cable is slacker?
Old Dec 9, 2011 | 11:33 AM
rst-ste's Avatar
rst-ste
yes mate, the r/l bearing still presses the plate no matter how much the pedal is adjusted. must be in the wrong hole as suggested above
Old Dec 9, 2011 | 12:54 PM
Canada1's Avatar
Canada1
Did you have your flywheel removed and resurfaced before installation of the new AP clutch and disk?
Old Dec 13, 2011 | 02:28 PM
fogulbennett
any news on this?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
