Erratic idling/stalling
Old Nov 21, 2011 | 06:56 PM
Takeshi's Avatar
Takeshi
Default Erratic idling/stalling
Whilst crawling through London yesterday, the car randomly decided it doesn't like to idle, erratic at best. Most of the time it would just cut out.
Pulled over and had a look at things, disconnected the ISCV for test purposes and the engine wouldn't tick over at all, reconnect and then it was back to dogdy idling. If you held it with a touch of throttle it was fine. Checked a few connections etc, but no joy.
That was last night. Parked up all night and just forgot about it and it then drove all the way home to Bristol the next morning without a hitch lol.
I took off the control valve and cleaned it up and refitted it, still idling fine. I cleaned it up a few months back already, as the car had/has a tendancy to kangaroo occasionally.
Any suggestions? My finger is pointing towards the ISCV, but any tips will be helpful.
Car is a 2.9 V6 btw.
Old Nov 21, 2011 | 08:34 PM
Shaun Wilson's Avatar
Shaun Wilson
maybe not of any use to yourself but i had a M reg Merc C-class that did the exact same and after weeks of confusion and cutting out it turned out to be a leaky vacuum pipe .
Old Nov 21, 2011 | 08:55 PM
Takeshi's Avatar
Takeshi
Ok well I just went out to take the car out, but it will not tick over. As soon as it catches, it just dies/idles badly?
I think i'll have to get handy with the WD-40 to check for air leaks.
Old Dec 3, 2011 | 06:12 PM
Takeshi's Avatar
Takeshi
Update:
Fitted a new ISCV, but no change. Worth mentioning that the fault is becoming more regular - it seems to play up after around twenty minutes, so it's obviously heat related.
It has settled somewhat - it will idle at a lumpy 500RPM alot of the time. I do think I have an air leak though, but I have checked with a can of WD40 etc, since I can't set the base idle.
Old Dec 3, 2011 | 06:52 PM
Fordmad!'s Avatar
Fordmad!
Mines doing the same (differentt car) if you find out the problem let me no!
Old Dec 4, 2011 | 07:05 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Bump for Nick.......its a Xr4x4 on a K reg btw.
Old Dec 5, 2011 | 08:16 PM
Takeshi's Avatar
Takeshi
Ok well I fitted a brand new ISCV and did some more head scratching - I managed to corectly set the base idle. Things were looking promising for an hour or two, apart from a bit kangarooing at times, until the car decided it wants to idle at 2500RPM
If I disconnected control valve the revs dropped to it's base idle. Plug it back in and it shot back up. Basically it has a mind of its own. At the moment it's idling fine, which is making this problem all the more annoying. I've checked the hoses, tried spraying WD40 around areas etc but it didn't throw anything up.
I've cleaned the loom plugs with contact cleaner also.
I've now thrown the towel in on this bloody car.
Old Dec 6, 2011 | 06:48 AM
Adam.'s Avatar
Adam.
Bump for Tuesday.
Old Dec 6, 2011 | 07:20 AM
Fordmad!'s Avatar
Fordmad!
Changed the ECU on mine and that helped, not sure if you have one! Nothing worse then this problem!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
muttsnutts89
Oct 31, 2010 08:59 PM
pezzerfocus
Ford Focus ST
Oct 10, 2010 02:43 PM
Dec 28, 2003 08:53 PM
