plz read re ongoing faut with my gti
hi em well if uve not read my threads b4 my escort gti is misfireing and misfireing really bad under load and also conks out when starting then doesnt start for a thew min iv tryd new coilpack/lambda sensor/crank sensor/maf/idle valve/leads/plugs/fuel pump+filter etc well now i put on a new ecu and the damn thing is still doing it and is still running really rich so iv disconected my new throttle position sensor as even tho iv put a new 1 on its still reading as the voltage is to hige at 4.5volts no matter what rev range its at well it runs a little bit better but still does as above... does any 1 kno what cud b making it run so rich and missfire so bad plz plz help iv spent bout 1200 on this fkn car to sort out its probs but no joy iv even jus done the cambelt? im doing the injecters n regulater nxt but i dont think itl solve it? apart from change the loom i dnt kno what else to do
can the mixture b adjusted? or the tps? its as if the timings out but its all jus been redone iv even had compresion test done today n now im outa money lol so iv gota do the rest me self n im stumpt but the weird thing is if i boot it from stand still the car goes really well n fa some weird reason its dam fast with no misfire or juddering it seems to just do as above when driving normal then accelirating to go up hill or on motorway?
07-10-2015 12:56 PM
cossirob
16-09-2015 07:39 PM
