Fiesta RST Problems
Old Feb 17, 2005 | 03:00 PM
hunter2003k's Avatar
hunter2003k
Default Fiesta RST Problems
Hi my mates frst is pretty knackered, but im not sure where to start. the main problem as far as i know is backpressure blowing the oil cap off, but it also ended up with clouds of smoke coming from the exhaust, and oil conimg out the dump valve, im going to strip all the pipework off it tomorrow and see if i can sort the back pressure problem, but i also want to know what else to look out for.
Dougie.
Old Feb 17, 2005 | 04:15 PM
Moonie's Avatar
Moonie
Sounds to me like the rings are knackered causing excess blow-by gas. This will pressurise the crank case and blow the oil cap off cap off. Will also be the cause of the smoke from the exhaust (could also be stem seals, turbo etc). The pressure will also be forcing excessive ammounts of oil through the breather and into the intake which is why there is oil coming out of the dump valve.
Old Feb 17, 2005 | 06:09 PM
hunter2003k
is there any easy way of telling if the rings are gon without pilling the whole engine apart?
Old Feb 17, 2005 | 08:44 PM
b13nde's Avatar
b13nde
well you could do a compression test but unless the rings are really bad then it wont show to much the only way is to strip it mate hows the hoilday moonie
Old Feb 18, 2005 | 03:25 PM
rabmc's Avatar
rabmc
U need to gead the head off and have a look m8 , even drop the sump and get pistons out for closer insoection , defo something up piston/ring wise
Old Feb 18, 2005 | 04:18 PM
Moonie's Avatar
Moonie
You can do a wet and dry compression test or take it to a grarage who will be able to carry out a cylinder leakage test (measures the cylinders sealing ability)
To do the compression test, first measure the compressions and write down the readings for each cylinder, next drop a few squirts of engine oil down the plug holes. Do a second compression test and if the the results are substantially higher with the oil then the rings are knackered (the oil seals the rings/bores)
rex647
Mar 6, 2022 06:20 AM
JK12
33
Apr 26, 2021 12:09 PM
28
Sep 8, 2015 07:10 PM
BRAM
Sep 8, 2015 07:11 AM
routemaster
Sep 7, 2015 05:27 PM
