AP 4pot CP6600 red callipers problem?? Pics added!
Old Feb 16, 2005 | 08:28 PM
Mr C's Avatar
Mr C
Default AP 4pot CP6600 red callipers problem?? Pics added!
Right i have a set of CP6600 4pot red limited edition calipers and 330mm disks and bell, 2wd Disk bells supplied by REYLAND, kit from ZOO. I have the job of fitting these to a sapphire cossie and the caliper doesnt make sense, If they are fitted so the wheel direction indicators are followed correctly and the hoses are on the inside (bear with me) then it means that the smallest piston is at the bottom (this activates the pad first giving a bit of "toe" to the pad?) is this correct?
This makes this a N/side item and means the bleed nipples are on the bottom!!
what car are these calipers specced for originally, Im guessing one with the callipers on the front of the suspo strut or were the bleed nipples just put on the the wrong end of this caliper for the cosworth application? Is the piston order correct and I just swap the nipples/joining hose? anybody?? Pics to follow when Photobucket is back online
Old Feb 16, 2005 | 09:07 PM
Mr C's Avatar
Mr C
The question really was which car did these get specced for that ran them on the front of the suspo strut not the rear like the Sierra. I am just going to swap the nipples for the hose to make these work
Old Feb 16, 2005 | 09:49 PM
CosKev3's Avatar
CosKev3
Looks like you've answered your question yourself m8
That looks the way to me
Old Feb 17, 2005 | 06:05 PM
Mr C's Avatar
Mr C
Yeah I know that really.
I just wanted to know why they would be supplied in a kit for a cosworth but not fit a Cosworth? Apparently these were NOT supplied by REYLAND, apologies
Old Feb 17, 2005 | 06:16 PM
Mr C's Avatar
Mr C
Seems they were just specced wrongly for this cosworth. SORTED NOW THANKS ALL.
Old Feb 18, 2005 | 09:18 PM
Mr C's Avatar
Mr C
Thanks to Martin at REYLAND for his help and suppying the bells
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
