s2 idleing strange when u press the brake pedal?
Old 02-12-2004 | 11:16 PM
RScrew69's Avatar
RScrew69
Default s2 idleing strange when u press the brake pedal?
Had this problem recently with s2 turbo. When your at standstill and idleing away, if u press the brake pedal the revs increase, and i've tried it a few times and it will always do this, any ideas as to whats up with it?
cheers
Old 02-12-2004 | 11:43 PM
MikeyXR2i's Avatar
MikeyXR2i
Normal, keep pressing it fast, revs will go up even more.
Old 02-12-2004 | 11:58 PM
RScrew69's Avatar
RScrew69
my girlfriends s2 turbo doesn't do it at all??????? i'm sure its an air leak or something along those lines. anyone had experience as what it may be?
cheers
Old 03-12-2004 | 08:18 AM
Alvyn's Avatar
Alvyn
check your master cylinder and brake servo are working correctly I'd say your brake servo's NOT (drawing in air)
Old 03-12-2004 | 05:44 PM
RScrew69's Avatar
RScrew69
hmmmm, interesting how can u deffo's tell if it is the servo? brakes are fine on the car. If its replaced is there a standard but uprated servo you can fit on?
cheers
Old 03-12-2004 | 05:52 PM
MikeyXR2i's Avatar
MikeyXR2i
mate, i promise you its normal, think about it, when you press the brake, you are reducing the amount of air room in the servo, this will pressure it back to the inlet manifold, so when the air pressure goes up, touch more fuel will be added so the revs will go up a little, i even tried it for you today in My Series 1, it only rised a minimal amount, and My XR2i does it.
Hope u can see what i mean.
Old 03-12-2004 | 05:54 PM
s1rscustom's Avatar
s1rscustom
yeah mine s1 does the same i wouldnt worry bout it, til brakes aint workin anyway, i never seen it as a problem, better to go bit high than than lower when brakin i would of thought
Old 03-12-2004 | 05:55 PM
s1rscustom's Avatar
s1rscustom
yeah mine s1 does it slightly i wouldnt worry bout it, til brakes aint workin anyway, i never seen it as a problem, better to go bit high than than lower when brakin i would of thought
Old 03-12-2004 | 06:02 PM
RScrew69's Avatar
RScrew69
suppose u guys are right when u come to think about it. oh well it'll keep then i suppose for the time being.....
cheeRS
Old 03-12-2004 | 06:11 PM
K18NEO's Avatar
K18NEO
mine .. the car starts to die.
Old 03-12-2004 | 07:38 PM
RScrew69's Avatar
RScrew69
hmmm, try turning the idle up a little, otherwise it might just be an air leak which is usually always 90% of the problem on a turbo'd car
cheers
Old 17-02-2005 | 01:27 PM
cossiematt's Avatar
cossiematt
My s1 also dies when i push the brake, if i holfd the pedal down then it will stall completely
An air leak sounds most likely, but does anyone know if this means that the air leak is definately in the servo or would there be the same symptons if the leak was for example the inlet manifold gasket or anywhere else?
I'm trying to establish wether i should replace the servo before anything else
Any help is greatly appreciated
Old 17-02-2005 | 07:52 PM
AKRS1's Avatar
AKRS1
my revs rise when press the brake pedal several times i think its normal
Old 18-02-2005 | 11:26 PM
cossiematt's Avatar
cossiematt
it ain't normal to drop though
muzzman1
30-09-2015 09:59 PM
Sp3no
27-09-2015 08:23 PM
The Enigma
12-09-2015 11:12 PM
Quick Reply: s2 idleing strange when u press the brake pedal?
