mounting my swirl pot help
Old Aug 31, 2011 | 01:21 PM
garrett's Avatar
garrett
Default mounting my swirl pot help
Can anyone tell me were and how I mount the small top hose of my swirl pot
Because it has to go to the cooling water tank but my standard 4x4 tank only has 2 big mounts
Hope somebody knows how to solve this
Old Sep 2, 2011 | 09:06 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
I'll have the same issue when I fit mine to my spec R tank. I think getting a hose connection bit welded in at the top will do the trick. Some people I have seen connect it in line with the turbos water return line but I would not want to do that personally.
kosienutter
Also is your tank the standard hard plastic one?
Old Sep 2, 2011 | 09:12 PM
martysmartie's Avatar
martysmartie
The aftermarket alloy ones have another union that it connects to, the standard ones don't so I guess you have one of these or one without the extra union? I guess you would have to get another tank or find somewhere else to connect it.
Martin
Old Sep 2, 2011 | 09:31 PM
garrett's Avatar
garrett
i have this one
Old Sep 2, 2011 | 09:52 PM
james kiely's Avatar
james kiely
you will prob have to go with aftermarket garrett with the extra inlet
Old Sep 2, 2011 | 10:26 PM
Cilly-jey's Avatar
Cilly-jey
i plan on drilling mine and putting a 8mm flanged nipple in mine as i have a brand new standard tank ready 2 go on in the winter.
Old Sep 3, 2011 | 08:02 AM
garrett's Avatar
garrett
do you mean how this guy has it , and is his save ????
Old Sep 4, 2011 | 08:31 AM
kosienutter
That's perfectly fine to me. He must have that nipple bolted in and sealed or something. An aftermarket 4x4 tank will only have the 2 holes but like I said welding another nipple at the top will sort this easily.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
