Tightening top strut bolt
Old Aug 26, 2011 | 11:13 PM
kaisersolsay's Avatar
kaisersolsay
Default Tightening top strut bolt
Anyone got tips on how to stop the strut spinning whilst trying to tightening the top strut nut?
Old Aug 27, 2011 | 12:27 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Generally they have a hex or alan key fitting in there so either hold it with a hex key or if it doesnt then ive jacked them up before to try and get tension on there or put the car on the fllor and tighten. make sure your not cross threaded also. if not then tighten a small bit then back it off. repeat process till the desired tightness is required
Old Aug 27, 2011 | 12:28 AM
paddyrs's Avatar
paddyrs
is there not a place for a allen key in the middle off it
Old Aug 27, 2011 | 01:07 AM
kaisersolsay
Not on Gaz coil overs unfortunately, they don't have a hex slot.
Old Aug 27, 2011 | 01:28 AM
paddyrs's Avatar
paddyrs
what do thay have my avo coil overs had a bit i could hold
Old Aug 27, 2011 | 08:22 AM
kaisersolsay
There's a tiny lug at the top which is of course used to soften / hardener the dampers. I didn't want to tighten the main nut whilst holding this lug in case I damaged the unit.
Old Aug 27, 2011 | 09:40 AM
AstoN_B's Avatar
AstoN_B
An eye for detail...
just under that adjuster should be a round bit with two flats on it, or similar, use a spanner to hold that while tightening. If suspension is new it should come with these instructions anyway. If not post a pic of the top and someone can arrow to the bit you hold.
Old Aug 27, 2011 | 05:53 PM
Churtz's Avatar
Churtz
As stated here...my gaz shocks have 2 flats for a 10mm spanner.
Matt
Old Aug 27, 2011 | 07:08 PM
martysmartie's Avatar
martysmartie
Impact wrench would be another method.
Martin
Old Aug 27, 2011 | 09:50 PM
kaisersolsay
Had another look and yes there's 2 flats for a 8mm spanner. The flats were hidden by there locking nut! Doh!
Old Aug 27, 2011 | 11:03 PM
AstoN_B's Avatar
AstoN_B
Martin
This would be fine for standard stuff tbh, my new suspension said to torque to specific amount, so i did. Although i believe once it's tight, it's tight so its not critical.
JK12
33
Apr 26, 2021 12:09 PM
bigluke200
14
Sep 2, 2015 10:35 PM
155lee
Aug 14, 2015 11:21 AM
RIB1122
Aug 12, 2015 08:49 PM
track.focus'd
Aug 12, 2015 05:53 PM
