Intermittent fans with A/C on
Old Aug 2, 2011 | 01:22 PM
Scottishrob79's Avatar
Scottishrob79
Default Intermittent fans with A/C on
Hi, first post here so please be gentle
Have had my 2002 focus TDCi since Fed but one thing is driving me crazy about it and it is only a problem when the A/C is on - I have climate control but only really use the A/C button for when I want want cold air. As I understand, when the A/C is on, the low speed fan should come on and stay on. The problem is that only happens half of the time.
The other times when I switch on the A/C, both the high speed and low speed fans cycle on and off (both at high speed), so I only get cool air intermittently. This can happen at any time, whether the temperature is warm or not and whether the engine is warm or not. For instance today its about 25c+ where I am. Used the car for 5 mins, left it 2 hours and then got cycling fans when starting A/C. Later on, left the car for hour and a half, got back in and low speed fan running as it should
I have had the condenser replaced recently and had the system checked for leaks and then refilled and he even came back out to check the pressure, so to rule out high pressure in the system. I have also checked the resistor on the fan assembly and the plugs and all seems fine. I have also checked the A/C relay and both fan relays, again all fine.
Anyone got any ideas, faulty rad switch or some sensor for instance??? (As I previously said, its a problem that is only there half of the time)
Old Aug 2, 2011 | 01:59 PM
Scottishrob79
Forgot to add, the A/C is working perfectly fine apart from the strange fan behaviour
Old Aug 2, 2011 | 03:54 PM
fegs66's Avatar
fegs66
I've had an intermittent fan problem with mine and a new pollen filter cured it
see this topic
https://passionford.com/forum/techni...t-problem.html
Old Aug 2, 2011 | 04:07 PM
Scottishrob79
Hi mate, the problem I have is with the cooling fans attached to the rad, not the heater blower
Old Aug 2, 2011 | 04:51 PM
fegs66's Avatar
fegs66
sorry didn't realise
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
dange
Sep 23, 2015 12:11 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
