Fitting coilovers
Old Jul 26, 2011 | 10:41 PM
kaiser_solsay's Avatar
kaiser_solsay
Default Fitting coilovers
Hi,
Fronts fitted no probs, however the rears seem to have slightly different ends than my standard shocks. I'm sure this is completely normal but just want to check.
Do I need new mounting bars to run through the bottom on the coilovers?
Old Jul 26, 2011 | 10:58 PM
botters's Avatar
botters
competant bodger
what car?
Old Jul 27, 2011 | 06:13 AM
kaiser_solsay
Yeah sorry, its a 4x4 cossie floorpan on a Mk1 Cortina. The coilovers are for a 4x4 Saph.
Old Jul 27, 2011 | 07:54 PM
Should just be the std eye bolt fitting on them.
Old Jul 27, 2011 | 08:10 PM
kaiser_solsay
Any pics?
Old Jul 28, 2011 | 07:10 AM
No pics but exactly same fitment top and bottom of damper, although bottom one may be wider that's all.
Old Jul 28, 2011 | 08:22 PM
kaiser_solsay
Ok, here's some pictures.
Looking on here, there doesn't seem to be any other rear setup where the rear shock passes through the middle of the spring.
See pics of my set up below;
And the rear strut top;
Old Jul 28, 2011 | 11:39 PM
kaisersolsay's Avatar
kaisersolsay
On all other 4x4 set ups I've seen, the rear strut sit outwith the spring and bolt to the arm. Mine however sit within the spring and have a threaded top like the front struts??? Does anyone know why the are different?
Old Jul 29, 2011 | 05:46 AM
Not seen that before on a sierra, I would have said it looks like the mounting points have been modded, but the seam sealer looks factory around the top, even the rear arm has a big bulge in it that I don't remember seeing before.
Old Jul 29, 2011 | 11:43 AM
kaiser_solsay
Anyone else seen this rear configuration?
Old Jul 30, 2011 | 05:48 AM
kaisersolsay
Is the rear arm perhaps from a estate model?
Old Jul 30, 2011 | 08:57 PM
kaiser_solsay
Anyone help?
Old Jul 30, 2011 | 11:41 PM
kaiser_solsay
More pictures. The rear shock is secured to the lower arm via 2 securing bolts.
See below;
Old Jul 31, 2011 | 12:22 AM
kaiser_solsay
The rear assembly was taken from a 2.0 twin cam 4x4 Sierra....were they a different set up to a Cosworth?
Old Jul 31, 2011 | 12:28 AM
kaiser_solsay
This is how the top strut is secured;
JoeyBoyden
Jan 4, 2024 02:36 PM
yatta
Sep 1, 2015 11:28 AM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
adam151082
Aug 11, 2015 04:50 PM
