Transmission help on a engine conversion!
Old Jul 18, 2011 | 08:42 PM
FocusWilliam's Avatar
FocusWilliam
Default Transmission help on a engine conversion!
Hi guys i have a 1.8 ford focus mk1, year 2000, and i just fitted a 2.0 ford cougar engine. With my 1.8 focus gearbox... Id also fitted the 1.8 flywheel and clutch.. My problem is the 1.8 flywheel's bolts dont line up on the 2.0 engine?
So is it possible to run a 2.0 flywheel with a 1.8 clutch on a 1.8 gearbox? Or do i need to run a 2.0 flywheel AND clutch in a 1.8 box?
Help please!!
The 1.8 flywheel is bolted on but its leaking engine oil through the two bolts that are missing due to it not lining up right.. Hence a slipping clutch
Old Jul 18, 2011 | 08:59 PM
2ndGear's Avatar
2ndGear
you will have to fit a flywheel from the cougar engine, the focus will be a dual mass i think and is bigger
Old Jul 18, 2011 | 09:13 PM
FocusWilliam
But my question is i have a 2.0 cougar engine with a 1.8 box.. Will a 2.0 flywheel and 1.8 clutch with 1.8 gearbox work?
Old Jul 19, 2011 | 03:26 PM
martysmartie's Avatar
martysmartie
It does not have a DMF, there are only 2 variants of MK1 that did!
I would say at a guess the 2L flywheel with the 1.8 clutch gearbox will be ok but I am not sure, the 2L clutch may just be uprated perhaps?
The boxes are however different the 2L will have the MTX75 box.
Martin
Old Jul 19, 2011 | 03:36 PM
LewisT's Avatar
LewisT
Have you tried turning the flywheel round in all six positions? the holes are not equally spaced so you can only put it on in one position.
Old Jul 19, 2011 | 03:45 PM
FocusWilliam
LEWIS YOU COULD BE RIGHT. im going to be doing the clutch tomorrow so ill probably try that! id love it if the 1.8 clutch and flywheel stayed on as this flywheel is nearly half the weight of the 2.0... would make more sense to run a 1.8 flywheel aswell because it will be a mish-mash of components to make up my transmission... im gunna try lewis' idea tomorrow when i get the box off.. crap weather here in peterborough today!
Old Jul 20, 2011 | 02:58 PM
mobb-black's Avatar
mobb-black
I was gonna say...my 2.0 has a 1.8 flywheel on and everything lined up?
Old Jul 20, 2011 | 04:54 PM
Churtz's Avatar
Churtz
+1 !!!
Old Jul 21, 2011 | 12:02 AM
FocusWilliam
Fixed! Turns out i lined the 1.8 flywheel up, 1.8 clutch on. Perfectly running 2.0 focus! Will be making a thread on its progress soon
Old Jul 21, 2011 | 01:03 PM
shalon's Avatar
shalon
surprised it ran the crankshaft pick up is on the flywheel and if its not in right it gets the wrong reference for no1 tdc
Old Jul 21, 2011 | 03:53 PM
FocusWilliam
Well ita running, and running well on a 2.0 engine with 1.8 flywheel clutch and gearbox
Kyle Langford
27
Aug 5, 2019 07:54 PM
mint_s2
Sep 2, 2015 08:58 AM
Old ford
Jul 31, 2015 06:50 AM
