strange starting problem...
Old Jul 10, 2011 | 10:03 PM
rst-ste's Avatar
rst-ste
Default strange starting problem...
Hi, i have a mk4 escort that ive just got back on the road after a few years.
It has a really wierd starting issue - it starts fine every time when the engine is cold, however when the engine is hot and i try starting the car it turns over really really slowly and wont start like there is no power in the battery. After 30mins or so when cooler, the car will start fine again.
As you can imagine this is a major pain when at the petrol station etc lol. Have any of you had this problem before?
Ste
Old Jul 10, 2011 | 10:21 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
id say your starter is knackered mate. common thing on these. Especially if not running a heat sheild
Old Jul 10, 2011 | 10:41 PM
Chopshop85's Avatar
Chopshop85
I had this problem as well. Pretty common I believe.
I got myself a new starter motor and wrapped my downpipe as the excite wire sits very close to the exhaust.
Old Jul 11, 2011 | 07:00 AM
Classic lazy/duff starter.
Old Jul 11, 2011 | 08:58 AM
rst-ste's Avatar
rst-ste
Ok thanks guys for your help, ill get a new starter and wrap my exhaust
Ste
Old Jul 11, 2011 | 12:04 PM
Chopshop85's Avatar
Chopshop85
Ste
Worth doing as it keeps the heat away from the starter and alternator. Helps them last a bit longer.
Old Jul 11, 2011 | 04:56 PM
chris m1's Avatar
chris m1
check out this link for a few more ideas...
http://mk4escorts.freeforums.org/hot...-tips-t11.html
Old Jul 30, 2011 | 09:25 PM
rst-ste's Avatar
rst-ste
Hi guys,
Little bit of a set back, i fitted a new starter & wrapped both the downpipe & starter with heat wrap tape & it still has the same problem.
Any more ideas...
Ste
Old Jul 30, 2011 | 09:40 PM
rst-ste's Avatar
rst-ste
Just seen this, i'll check the leads & connections, put a gob of copper grease on there & see if that helps....if not guess i'll try a transit battery.
Old Aug 17, 2011 | 10:02 AM
rst-ste's Avatar
rst-ste
Sorted, fitted lucas lrs 732, direct fit. £65 from here:
http://www.westlancsautoelectrics.com/
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
