More Stage 3 Questions
Old Apr 7, 2004 | 11:35 AM
Nik_W's Avatar
Nik_W
Default More Stage 3 Questions
I've just taken delivery of a set of 803s and 3 bar map sensor. I also have a Ahmed Bayjoo stage 3 chip to go with them. I am running standard T3 turbo and 2WD intercooler for now. What sort of boost can I run with this sort of set up and would I need to change the plugs?
Cheers!
Old Apr 7, 2004 | 11:45 AM
Guinnless's Avatar
Guinnless
Keep the boost to around 18psi and swap the plugs for NGK9s from one of the traders on here. Stu etc
Old Apr 7, 2004 | 12:01 PM
Nik_W's Avatar
Nik_W
Thanks for that. What sort of power can I expect at 18psi?
Old Apr 7, 2004 | 12:23 PM
Stage 1 boost = stage 1 power 270bhp simple
Best bet to fit a 4x4 or 500 cooler and crank up the boost to 25 spike and 21 held !!!
Old Apr 7, 2004 | 01:44 PM
Guinnless's Avatar
Guinnless
18psi is not stage one boost
2wd T3s won't like being driven at your quoted boost levels. A 4x4 will be closer to your quoted figures.
A T3/4 would be ideal all round.
A held 24/25psi then
Old Apr 7, 2004 | 01:55 PM
Steve,
By Stg 1 boost I meant 15psi, but some do spike at 18psi
A T3 in GOOD health WILL be ok at 20+ psi (for a time) Mine Is
But as you say t34 would be a better bet
Old Apr 7, 2004 | 01:57 PM
Steve,
By Stg 1 boost I meant relatively speaking i.e. 15psi= 1 bar= stag 1, but some do spike at 18psi
Old Apr 7, 2004 | 10:06 PM
HI.
You can learn something new anytime, i thought 15psi was stage 1, until
i emailed karl norris of NORRIS MOTORSPORT, his stage 1+ will peak at 24psi
and held 18psi at 6000rpm dropping to 14. at 7000rpm, to cut a log story short its in the chip parameters, on yellow std injectors sierra cosworth. i was thinking
like everyone else based on map sensor ie 2,bar set up 15psi boost. karl
does his chips from scratch, where i think most tuners have a base file to start with.
Dave.
Old Apr 8, 2004 | 12:19 AM
Sorry for hiking... A set of 803s, 3 bar map sensor, Ahmed Bayjoo stage 3 chip, Engine Breather, Forge RS500 intercooler, Standard T3 Turbo in a hot tropical climate (singapore). How much boost can I run?
I have a Stage 3 T3/T04S (60-1 compressor) with Tial external wastegate and custom exhaust manifold. How much boost can I run with a Stage 3 chip with the T3/T4?
Old Apr 8, 2004 | 08:27 AM
Guinnless's Avatar
Guinnless
Originally Posted by davidreader5
HI.
Dave.
Yes mate we all know about Karls Stg1 "Gunship" conversion . It's very cleverly done to extract the most out of a standard setup. But Karl needs to be very sure of your engine.
With a Stg1 OTS chip you'd be better of peaking around 17psi and holding 15psi.
HTH
Old Apr 8, 2004 | 12:49 PM
Nik_W's Avatar
Nik_W
I'm not to fussed about killing the T3 as it will be replaced in a couple of months but would it be safe for me to run say 20psi on 803s, 3 bar, stage 3 chip, standard intercooler, -31?
Old Apr 8, 2004 | 02:23 PM
Switch's Avatar
Switch
I run 21-22psi held on a T3 hybrid, 4x4 cooler, greens and a baileymotorsport chip power is excellent.
turbo-nutter, i would advise changing to at least a 4x4 i/cooler asap, you can pick one up for Ł75 ish then sell your 2wd one for approx Ł40.
Old Apr 8, 2004 | 03:36 PM
Nik_W's Avatar
Nik_W
Yep, that is also the plan, just gotta build my paypal account up a touch more and start searching on eBay
Old Apr 8, 2004 | 04:28 PM
Hey, I've got one for sale. Interested? Do you know who I am?
Lemme check out the postage from Singapore...
Old Apr 8, 2004 | 09:51 PM
Nik_W's Avatar
Nik_W
Yep, I know who you are, I think I gave you the link to PF
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
A.t.p
Sep 29, 2015 05:04 PM
