rs1600i- fuel pump problems
Old Apr 6, 2004 | 09:19 PM
Default rs1600i- fuel pump problems
Help
just got an rs1600i. only problem is that it wont start. The fuel pump is not running, if you put a 12v feed to it it does run. heard that there is a fuel cut out switch in the wheel well but i cant find it?!? help please
Old Apr 6, 2004 | 09:31 PM
rs1600i
Old Apr 7, 2004 | 01:41 PM
CabrioTurbo's Avatar
CabrioTurbo
ARE YOU SURE ITS NOT THE FUEL PUMP RELAY?
Old Apr 7, 2004 | 07:58 PM
sm's Avatar
sm
ive never seen a fuel cut off on a 16i, try another fuel pump relay, u cant get them from ford anymore but mk1 &mk2 golf gti's use the same relay as a 16i, proberbly find one in ur local scrappy or most vw specialists have them
hope this helps kev
Old Apr 7, 2004 | 09:43 PM
HI,
TO check relay k jetronic bridge pins at relay base 30 and 87 pump should run
with ignition on, maybe off, check this site for rs 16i,
www.durhamrsoc.co.uk under electrical it list fuel safetypump relay located on
steering column???, k jetronic systems usually under o/s footwell, xr3i etc.
if the system works exactly the same as xr3i there is a fuel cut off
but designed to shut off fuel when u lift off throttle, and kicks back in at around 15oo rpm, for economy, but i think your problem is either the fuel injection fuse or relay, so bypass it and if it runs u know its the relay, if not go for the fuse
or check for continuity no breaks in the wiring.
Dave.
Old Apr 8, 2004 | 10:29 PM
thanks to everyone who repplied it was a faulty relay
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dlwarrior
Aug 5, 2015 10:19 AM
