Mk 4 escort 1.3 eclipse exhaust splutter
Old Jun 27, 2011 | 04:05 PM
Linnnaim's Avatar
Linnnaim
Roy
Default Mk 4 escort 1.3 eclipse exhaust splutter
Hi can anyone please help? , I have a 1987 mk 4 escort 1.3 , 31,ooo original miles , its just passed it's mot everything was spot on , just a warning about the exhaust front Downpipe which was a bit rusty ... So I have just changed this to a brand new shiny one which matches the rest of the exhaust..... But I now get a farty splutter from the exhaust mainly when I de-accelerate , it does it a bit when you accelerate hard , but its mega when you de-accelerate , I,m considering putting the rusty old one back on , but the rag and bone man took it .. Any ideas ??????? Thanks Roy .... I have double checked everything gaskets the lot , it drives great ??
Old Jun 27, 2011 | 06:07 PM
ChrisH's Avatar
ChrisH
Get someone to put their hand (with a bit of rag) over the tail pipe and check for leaks.
Old Jun 27, 2011 | 06:22 PM
Linnnaim's Avatar
Linnnaim
Roy
Thanks Chrish , I will try that , I,m sure it's all as tight as I can get everything , I have used that paste stuff as well on the joints , I will double check .. Roy
Old Jun 27, 2011 | 08:16 PM
ChrisH's Avatar
ChrisH
Did you clean all the joints and flanges up with sand paper? Otherwise you may be mating a fresh pipe to a rusty flange and the build up of shit it not letting it sit flat.
Old Jun 27, 2011 | 08:55 PM
Linnnaim's Avatar
Linnnaim
Roy
Good thinking , I will double check everything tomorrow , thanks .. Roy
Old Jun 30, 2011 | 11:17 PM
Linnnaim's Avatar
Linnnaim
Roy
Smile
Thanks Chrish , I went over it all again and found one of the bolts on the down pipe was seized , I thought it was tight against the manifold but it was just tight against itself .. I managed to free it up and it's all spot on now ... Obvious really but thanks anyway , it sounds spot on now , .. Roy
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
