Gartrac Ecort rwd running issues
Old Jun 13, 2011 | 08:05 PM
cozi500's Avatar
cozi500
Default Gartrac Ecort rwd running issues
Hi all, the issue im having is my c20let engine starts and runs fine when cold, every time i take it out and the engine starts to get warm the engine starts to hold back and splutter a bit then stall once stopped, the spark plugs are really sooty black, now it has not logged any fault codes in the ecu, things ive done so far, change the ecu, changed MAF sensor, CTS, ISCV, TPS, check all voltages to the sensors, checked all the earths, nothing, the only things i havent changed are the ignition coil lead/HT leads/ plugs/dizy, would a coil lead start to break down once it gets warm and cause this, weak spark hense sooty plugs? dont know desperately seeking help, when cold, its crazy to drive but not long before the fault appears, but disapears when cold, then re appears when warm again, any help please
Old Jun 13, 2011 | 08:06 PM
JonnyBravo's Avatar
JonnyBravo
Try a coil, my mates did similar and that cured it.
Old Jun 13, 2011 | 08:07 PM
cozi500's Avatar
cozi500
Old Jun 13, 2011 | 08:09 PM
JonnyBravo's Avatar
JonnyBravo
What fuel pressure regulator are you using ?
fiend's Avatar
fiend
Can't help with your issue.
But that screamer pipe design looks restrictive.
cozi500's Avatar
cozi500
Yes will try that, would it cause this sort of fault then.
Old Jun 13, 2011 | 08:11 PM
cozi500's Avatar
cozi500
Yes it looks retrictive at the moment new one ordered, but this dont work until 16psi, but the problem is befor that even works,
Old Jun 13, 2011 | 08:43 PM
cozi500's Avatar
cozi500
fuel pressure reg is after market adjustable upto 7bar had it set at 4 bar on idle as this is what its supposed to be set at on phase 3 but it seemed to be over fueling so i turned it down to 2.5 bar but as i say it starts to die once it starts to get warm, and cut out but does restart but wont tick over then, it dont back fire it just seem to splutter and hold back, i check the plugs every time and there sooty black again.
Old Jun 13, 2011 | 08:48 PM
ChrisH's Avatar
ChrisH
When it was at 4 bar did it run alright? 2.5 Bar sounds a little low to me.
Old Jun 13, 2011 | 08:55 PM
cozi500's Avatar
cozi500
No it did exactly the same, could it be the MAF sensor to close to the turbo, as the turbo is uprated with a 4 inch inlet, could the sensor cope with the amount of air flow, but it dosent show any faults on the ecu fault test
Old Jun 13, 2011 | 09:00 PM
JonnyBravo's Avatar
JonnyBravo
Is that on a stock ecu ?
Has it ever run right ?
Old Jun 13, 2011 | 09:52 PM
cozi500's Avatar
cozi500
Its a vmax evo 5 ecu, genuine chipset and power wheel, it ran fine when i had the wrong MAF sensor on it, it was AN xe not a c20let one
Old Jun 13, 2011 | 09:56 PM
JonnyBravo's Avatar
JonnyBravo
TBH I can't say I am suprised that its running a bit odd, that combination of engine parts really should be run by a standalone ecu.
Have you tried another LET MAF on it ?
Old Jun 14, 2011 | 05:15 AM
cozi500's Avatar
cozi500
no not yet but what iv noticed is, that the mesh is missing both sides of the MAF, dont know if that would make any differance though.
Chas
Sep 21, 2015 08:57 PM
Bailes1992
Sep 3, 2015 02:17 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
yawiejon
15
Aug 9, 2015 06:36 PM
Red_bull
Aug 9, 2015 08:34 AM
