Fault codes Mondeo mk2 1.8 zetec.
Fault codes can be looked up on websites like: http://www.dtcsearch.com/
However the codes you name do not exist.
P-codes range from P0000 thru P3FFF. No p4... or higher is technically possible.
How did you obtain these codes and from which ecu (abs, engine, airbag)?
Engine ecu. maybe it just tricks me because i used The bluefin from my 99 st200 but on Google it did show a code called 9202 and it was something about some fuel component.
Si B
12-09-2015 06:49 AM
